Results 1 to 2 of 2
    Non-member Spidey's Avatar
    Lincs
    windscreen washer fuse.....
    My front windscreen washer has just stopped working, if I pull the stalk it does the usual 4-5 wiper turns just no screenwash or sound from the motor. the rear washer spins up ok.
    I've
    Non-member scratcher's Avatar
    Milton Keynes - ish
    Re: windscreen washer fuse.....
    aren't the pumps on the same fuse?
    i had this problem and it turned out to be a seased pump. i don't have a rear wiper or washer so i just swapped the pumps round.
    try testing your pump to see if its that.
    i just noticed the other thread for this
