coilovers
hi, just seen this web site on the manifold thread and noticed the fk coilovers, seem reasonably priced, has anyone bought some? views..
http://www.kamracing.co.uk/renault-r...over-kits-960/
have previously had avo's were good but corrode if you don't greese them up.
also does anyone know of any companys making coilovers with a shorter strut body as the avo's when set at quite a low hight, which is the look i like, i had to remove the bump stops which means only about 20-30mm travel
tar rikki
Re: coilovers
Fk is more of an affordable shock, the price seems about right to me. I had Highsport silverlines on my daily runner which were great for the money, but you will find that the highsports will corrode also unless you get the silverline versions which are a little more expensive. Dont forget that these coilovers a fixed damping, height adjustable only.
A company called Venom Motorpsort (VW scene) are a main dealer for FK if you go on there site it explains what you get with each range of kits, hope that helps.
http://www.venommotorsport.com/manuf...ory=Suspension
Re: coilovers
many thanks
