Scoff
no, the grey wire on the 3pin plug is tacho signal, it does not connect to the fuel pump. You need to connect the tach output from the clio ECU to this wire.
disregard the black ground wire, you should be earthing the ECU loom in its normal places (I forget where)
yes the clio loom has its own fuel pump relay, so the output of that needs to be spliced into the fuel pump live wire. you can get to this in the drivers footwell, behind the plastic cover in the pillar. Its the thick white wire in the corner of the connector from memory.
yes you can use the R5's starter motor wiring.
