anyone have a tried and tested epic method please ??
ideally want to soak them in some magic liquid that feeds
on carbon
on carbon
petrol or parafin?
drill and emery
hot parts washer, shot peening or just elbow grease.
I might also be worth leaving them to soak in some coke cola for a while, that stuff can shift enamel off of teeth if left for a few days so might do the job for you?
15 minutes! I wish I'd known that before
Stiff wire wheel in the Dremel on fastest setting.
ive always slapped the valve in a drill- high speed- and then simply run the corner of a piece of metal over the valve face. i finish off with wd40 and coarse paper working down to fine paper to a mirror finish
yeah, but no longer than 15mins, else it eats away the threads in the body.
it bubbles quite violently, and you must do it outside!
when done - scrub it with a wire wool scouring pad - the ones with a pink soap embedded in it. - brings it up nice. - make sure you rinse thoroughly. - then dry it else you get white oxidation build up!
