This looks like a nice piece of kit....If only I had the money!!
http://cgi.ebay.co.uk/rebuilt-T25-tu...d=p3286.c0.m14
Sounds expensive for what it is TBH, I can get a tomcat T25 new for not much more than that starting price from a turbo supplier.... plus other hybrids.
I think the 'don't give fantastic gains' is the key here Raj. It'll be more efficient/reliable at higher boost levels but the overall performance isn't vastly improved compared to an OE turbo.
Improve performance in what way? Road driving? Track? On the strip? Bragging rights power figures down the pub?
Unless Adam has worked his magic, I personally wouldn't want to be running a Tomcat at 20psi. I'm not saying it's not possible, but the cold wheel will be outside its happy zone. For the same reason, why d'you think so many Tomcat turbos die so often when they're hooked up to gtt's & the boost is increased?
The problem with increasing power, vnt setup aside, is that there'll come a stage when a bigger turbo is required, and with that comes lag. If it's a drag/track use turbo, that's not so bad, but on the road it'll make for a cr8p drive, imho.
the thing is, it does matter! yes im selling it once its completely finished but id still like it to perform better than a std T2.
call me daft or whatever,but when i sell the 5 i want it ready to go for the new owner with no faffing about. i could put it up for sale right now as its basically finished,but i want to fit an afr gauge and also do the 2nd stage enrichment mod need to know abit more on this though.
so...It DOES matter
I know they have reliability issues when moved straight from the Rover without a rebuild but I thought Tomcats turbos were decent units for power? Not used one myself but I remember Jamie using one to get 197ish BHP (backed up by traps to match) at 18-19psi
How does this unit differ from the full T25 I have from AdamL?
the reason i had the tomcat unit rebuilt was because i thought a t25 would give me more power and not be very laggy and suit everyday road driving. just after abit more poke,not mega power. no track or drag use although i was hoping for it to perform a little better in a straight line over the T2.
I personaly found a full T25 both a 200sx and Tomcat a fantastic upgrade over the T2, but that is just my opinion. If it's been rebuilt then I can only guess it should be OK for a while!? It's still a garret.
I could not be doing with the T2 spooling nearly all the time and found it a great compromise with good response on the road and some OK times up the stip.
Try it! You might like it!
What were the trap times/speeds?
Going on Jamie's figure, that's only ~20hp more than an o.e unit running a similar boost level. It's a power gain, of course, but a fair bit of hassle along the way in achieving that (sourcing one, rebuild costs, bearing upgrade, fitting issues), hence the 'not fantastic gains' comment.
Just my opinion though. I'm sure there's plenty of people out there happily running them on their gtt's...maybe
Like all engine modifications, different parts suit different people and different styles of driving. The tomcat is a fair compromise for most people I'd say. it's going to make better power than the T2, no two ways about that. You have to be prepared to trade off some responce to get it though. I personally *hate* the T2 on the GTT, so for me it would be a great upgrade on a daily driver. Not everyone feels the same way as me though, which is fine, you just have to do whatever the hell you like best!!
Hey, it's a (rare) tech' thread with (equally rare) good discussion
If I was told correctly, Lloyd Bush used a Tomcat spec turbo, from TDL too I believe, to achieve the 11.9 sec pass.
The only thing I don't like about Tomcats is the exhaust housing, in my opinion they're limited to a certain amount of power, and i'd cap that at 250bhp. If you're after power, it's not ideal to be running out of flow... Although the turbo is the least of your worries on a 5.
250hp out of a Tomcat?
Didn't that blower have larger wheels fitted though?
I'm talking bogo spec Tomcat, with regards to Adam's 250hp comment.
If ya talking about a hybrid Tomcat, that's a different kettle of fish, and now we're going off on a tangent
standard tomcat with 360deg thrust, etc, he told me.
I didn't think the Tomcat wheels looked much bigger than a T2, and thought Bushy's fastest trap was ~111mph, hence querying the 250hp shpiel.
You geezas on a wind-up?
His 11.9 was 111 or close.. but fastest trap was 115...
..but 0.49 is what you find on the quickest c1j's in the club, stuart's included. whilst it's certainly a choke at those levels you still have to balance it with responce. part of the reason why bushy's car went so well was because it was responsive. no lag in the launch or between gears at all. a T28 with 0.64 is not much use on the drag strip, far too lazy, especially when boost levels get high. It might be fine on a race track, but I wouldn't know about that..
quite a bit bigger mart, 50 trim I think ? adam might be able to confirm that.
Robby from down here has proved T2 housings can make good power. 113mph is his best I think. Mind you, it's a very rare .63 housing and that's done a 113mph. Although that's not running a 62 trim exhaust wheel like the Tomcat.
It's the inducer that's larger on the Tomcat, Mart. The exducer is still a few mm's larger than the T2, by how much I can't remember
IIRC, Bu$hy was at 25psi on the Track and Road roller when they measured it at 247bhp.
Slightly off topic... I agree with Scoffs comment there, my fastest run i did was with a .49, i tried the same tune on a .64 gt28r and i could never gain my 60fts or 330s back no matter what i tried... The GT28 imo is a brill unit, but just isnt responsive with a carb fed c1j...
Also to add, a local friend of mind bought an old tomcat and rebuilt it himself in his shed with no experience in that field, i set the car up to 20psi and to this date 18 months on its still going strong with a fastest run of 104mph at pod, (stock engine and cam)... I wasnt a fan of tomcats and told him it wont last but hes proved me wrong...
It's the thrust bearing that'll give way before anything else on those, Rob. Idealy you want good oil pressure higher up the revs, so the load is taken away from the boost. Must be a good engine
Thankyou, Rob
Proving that the T2 is as good as I was hoping.
Just the .64 Allan.
I've just received my rebuilt Tomcat which I've bought from BluntyR5GTT. Thanks for that!
My question is: Anybody has experience with the blow-off valve which is integrated on it? Could it be used? Or shall I better blank it off?
Thanks James5!
Is this the blanking plate from forge?
http://www.forgemotorsport.co.uk/con...roduct=FMBPT25
Shall I order it or it can be made from a piece of metal plate?
And which Forge BOV will fit there?
THX
I can not confirm if the cosworth one is the same but stud pattern does look the same, could be worth trauling the rover forum's, 5teveL is a member on a few and maybe able to offer some advice as he has had a view Rover coupe turbo's himself over the years.
blanking plate for sale on the rovertech forum -
http://www.rovertech.net/forum/viewt...127097&start=0
to be honest you can alweays make one yourself out of 3mm or 4mm thick metal.
That would be easier than ordering such a plate to Hungary.
Or just trying to find a higher tension spring to be able to use the BOV @20psi.
