Well I have fitted this Engine into my Clio 16v.
The Engine Came from a Laguna 2,0 T. Only a pissy 170Bhp, So that was no good, Did some home work and came up with the Injectors and Turbo and ecu were different.
What we decided to do was get a Turbo from a Megane 225 R26 and Injectors from a Megane R26R ( the R has a better spray pattern )
Now i Didnt think about the fact that the F4RT Block is a 6 speed Box setup, i didnt want too use the NUM big NDO box from a x trail ( Lol ) So i decided to get a custom plate made, Once i had looked into this i decided i would have too re mortage the house :)
After much humming and Haring, Steve, ( Speedy ) and i came up with the best plan ever, Clio F4R Block with the F4RT Head and Internals, Steve did some home work and we get every thing sorted, Steve Kindly donaded the block that was in good shape.
I stuck the Crank/Pisons and Rods into the F4R Case in a night and then had to have the head Adjusted to suit the F4R Belt as the F4RT uses a water pump on the belt and not as a AUX.
...... to finish.....
