Door hinges....
Hi, im having a bit of a problem with my doors the car is away being sprayed at the moment and the old doors are the Torq type that secure to the hinge and the new doors ive got are the Roll pin type ones. Are they interchangable ? Do i just need to buy new rool pins or better off using the Torq bits still.
Thanks Leigh.
Committee, South East Regional Rep
Re: Door hinges....
You can use the roll pins hinges (New 5's) what you will find is that the hinge on the car will need to be enlarged slightly to take the door pin and the rest of the kit should come with the bits for the door. I had the same problem on a previous R5 and I removed the torx jobbies and put the roll pin kit on and job was a good un.
Re: Door hinges....
Ok i will give that a go. Thanks
