Re: differential oil seal
Hi Dave,
You still having probs with that? am assuming its the splined shaft side on the drivers side of the box?
olidaviesuk
Hi Dave,
Thats the one Oli, still leaking and starting to make a mess, so want to sort it once and for all now.
i had the same problem with because of the gripper diff, the spline shaft moves in and out which causes it to leek the fix the problem i fitted two diff seals cut down the out side of edge of the second one to make it fit straight on top of the other seal:)
Thanks Ted:)
I did try putting two on, but didnt cut the second one down so it leaked:crap:
