WANTED ASAP - Quaife diff or other for R5 GTT. With or without gearbox etc.
There was one for sale on the cliosport forum last week but not far of new price, with the gtt box I think you need to get some machine work done on internals to get it to fit, but on the later clio boxes 172 etc.. they bolt straight in. Also the bearings on the 172 boxes are better quality than the JB3 box. Only downside to using one in a gtt is you loose the use of GTT speedo
You can still use a Gtt speedo by putting a ring gear on the driveshaft like an abs ring;)
Don't the 172 boxes have shorter ratios that the 5GTT JB3?
If you want fast 5 use the 172 box because shorter ratio makes the turbo hit full boost quicker due to the increased rpm:smokin:
