where the injector restsors are in here ive run some tests and cant find any blown or open circuit ends be it very small kohms cheers
http://i73.photobucket.com/albums/i2...ictures018.jpg
Am i right in thinking that you would have to un-solder the resistors (once you've found them) to check them properly as you will be checking the resistance through the rest of the circuit otherwise?* :confused:
*Beginners electrician Skills
i am an electrician lol not an electronics genius yes i guess you would have to unsolder the resistors to get a true reading but ive identified many of the resistors in the board by there stripes and my results are only a few kohms out so not to bad
They are shunt resistors for the injectors?? Have you lost a injector output or looking to change the resistor pack to run bigger injectors?
If its a lost injector output then you looking for a driver chip normally mounted to a heat sink, the resistors protect these drivers.
just fitted my bigger injectors which are low ohms instead of the standard high ohm ones and on one ecu there are running constant so i guess ive blown the resitors up ect so yes would like to replace so i can run my low ohms ones any advise would be great
You have blow the driver outputs i think due to the current loading of the low resistance injectors :cry: Scoff's you man i recon to repair or point you in the right direction.
The resistors you are ment to use with them injectors limits the current and protects the drivers. The word is Fail :D
cheers for the reply mate
scoff's the chap for it but he's said it blows the outputs, not resistors. think its the two large ones, they capacitors? one has a green label in your pic, think there's just 2 firing 2 injectors each
