Trigger wheel and sensor.
Right then boyos
I have been savagely let down by the bloke that was supposed to be sorting my megasquirt loom and such for me. But we'll not get into that............:mad:
Unfortunately I'm now going to have to do it alone and try to get the car going. The bit I'm stuck with is the trigger wheel and sensor. How have people attached them? Has everyone welded the trigger wheels to the crank pulley? What about the crank position sensor? How have you guys mounted it?
Any help would be much appreciated thanks fellas, I've come stuck with this and am fast loosing the love for the old girl
Re: Trigger wheel and sensor.
Not too sure but could you run the sensor off the fly wheel would the mega squirt read the flywheel pattern. Do you know what flywheel your using from there we can work out the pattern and find out if ms will run from it ;)
Or if not this is an old thread about trigger wheels for the c1j ;)
https://www.rtoc.org/boards/showthread.php?t=15058
Scoff also does this trigger wheel and a pre made bracket for the c1j.
http://www.efi-parts.co.uk/index.php?productID=126
Could be worth an email to ask if he has put one on a Volvo lump or if it can be modded to fit.
Thanks JP I may just give him an ask, I guess he's my best bet
Are you running ms2 and coil pack
