On another forum someone has just flagged due to the standard clio 1.8 16v flywheel I can not run standalone management and have to run a clio 172 one?
Can anyone confirm this?
I think you can use a volvo 440 200mm though IIRC Rich... or was that on the C1J, brain is like a sieve these days :scratch:
If not a 215mm may be better anyway for what you want to do... I thought you were going custom though ?
Yes rich, 172/182 is preferable, or later Volvo as Steve says, You need the 60 tooth pattern on the flywheel. Or, you at least need to cut the "double" filled teeth (2 of, 180° apart) into 2 seperate teeh. Swapping the flywheel is the better option though. I have some 172 flywheels kicking about if you need one. :)
I think the f7r 710 (megan) flywheel has a different pattern than the other's which I think the megans is 60-2 due to the dizzyless head
If that is the case I have a couple of megane flywheels and maybe thats why I don't remember changing the flywheel on the F7R Megane lump I put in Phatty.
