air leak at carb
after trying for to find where i had a boost leak around the carb i have managed to find it i think. next to the main jet there is a spring loaded bar and at the end of the spring loaded bar there is a square with a bar throug it and is leaking from there as a pipe runs from here to the outlet on the lobster pot. dose this mean the carbs working fine is it bust or will stripping it down and carrying out a full overhaul cure it any help thanks.
Re: air leak at carb
thanks for that i thought i had a problem after looking for 2 hours and finding it :laugh:
