1 Attachment(s)
Need part number to show model car and version
I am in need of some assitance I have a part number for a renault throttle body but need to know what car and model it is of 7700871215.
I was told it was a clio 172 phase 1 throttle body but I have checked my dialogys and there are 2 x part numbers for the cable throttle body and the one I have is neither.
The reason I am checking is that i have gone to fit it tonight only to find out that this throttle body does not align up with the bolt holes on my inlet plenum???:confused:
Engine is ready to drop into the car pending a cable throttle body?
The numbers I got of my dialogys
7700113285
8200053557
Re: Need part number to show model car and version
Ashy cheers for the advice on the Cliosport site matey will do that.:)
If moderator want to delete this post please do:):ashamed:
James, as I just posted on cliosport
"Altough looking at that throttle body it looks like the meganne type? I'm sure the clio ones don't have the water cooled / heated section."
if its of any interest james I use a volvo T5 throttle, it's 60mm, it only takes a re-drill and tap of the plenum to fit. 60mm might be a bit big for what you want though.
the first number you posted is not a valid part number, possibly just the casting part number of the housing......
no more i can tell you on that part , sorry
Scoff
Cheers Chris there are a couple of Volvo T5's down my local scrappy which I can rape for bits.
