Brigsy
Pah haynes figures, it ain't a black art infact very easy. 15 min job tops. If you have managed to replace the shoes then setting the adjusters is easy.
Undo the handbrake cables fully both sides. Wind the adjuster out on the shoes until the drum fits on nicely, without binding when fitted. Its one of those jobs you get a feel for over trial & error. You need the drum to slide on over the shoes. Do both sides the same, adjust both handbrake cables evenly until you get the desired amount of clicks. The Brake pedal will have less travel too, brakes will feel so much sharper.
Also make sure there's no lip on the outer of the drum, if you leave a lip on you will pull the shoes off if you need to get the drum back off.
My grandad taught me this years ago, has never failed me yet. I prefer the handbrake on drums any day of the week over discs. Now get out there and adjust them drums;)
