Electric blue phase 1 gt turbo
Something has come up and I could do with raising some extra funds.
What I've got is an '87 phase 1 in electric blue.
The lower half of the car has been painted previously to quite a good standard and there's no rot around the screen.
I've had a quick look underneath and all seems well with no welding required.
The car was supplied with a v5 but no keys so I bought and fitted new door locks and loosely fitted an ignition barrel
It's showing 87k on the clicks but I've got no idea how accurate that is.
I bought this as a rolling shell for £600 last year and spent £430 on an engine and box including fitting from billy but it appears the headgasket may be gone ( mayo in rocker cover ) one engine mount is also gone.
It's got a brand new volvo 480 turbo clutch fitted that's seen no use.
Recently i've replaced the fuel pump relay and the reserve pump as these were both shot. I've also cured a fair few fuel leaks.
All the phase 1 interior is there although the black outer bolsters are worn as is always the case with a phase 1
As far as trim goes, it's missing a front bumper and grille.
As purchased:
http://i37.photobucket.com/albums/e9...photo-1393.jpg
How it will be supplied
http://i37.photobucket.com/albums/e9...E/image-11.jpg
http://i37.photobucket.com/albums/e9...E/image-12.jpg
http://i37.photobucket.com/albums/e9...E/image-13.jpg
Short vid of it running
http://youtu.be/lQh-bbKhHMA
I'd like to see £850 for it as a running project.
Thanks
Ross
Re: Electric blue phase 1 gt turbo
What needs doing to get this back on the road? And do you have any engine n interior pics?
Cheers..
Front bumper sourcing and fitting
Front indicators fitting
Washer jets fitting
I've put a new ignition barrel on but not fitted it to the column
Engine mount replacing
Headgasket. Although I've not confirmed that the headgasket is blown, I'm selling it as such to save any confusion.
There's probably a fair few minor jobs that will pop up along the way too.
It is a running car though so is a good base to start from and you don't get much rarer than an electric blue phase 1.
As for interior pics, ill sort some out as soon as I can get down to the unit.
Thanks
