Re: 1.8 16v into a campus...
markey b
just wandering how many people have done this?
i've got a spare 19 16v engine, and fancy putting it into a ****e looking campus just to take up the road to snetterton for kick.
i've got a complete engine and running gear from the 19 as i dropped the subframe, and kept all the wiring loom
just a few bits im not sure of, will i need GT tank with an injection fuel pump? also can i use rear mount from the 5 on the 16v gearbox? lastly, can i bin PAS pump and just use shorter belt or is there a trick?
cheers in advance, if its simple(ish) i'll hunt out a campus to play with :agree:
Not sure about the tank.. but you will deffo need the pump
PAS steering setup can be binned... Use the brackets from a 5 GTX
You can use the 5's Gearbox mounts on the valver box and you need a 5 GTX engine mount bracket ... you will need the speed cable from the valver box tho and clocks
im no expert on reno's but im sure all you would need is the inj pump unless its a intank jobbie, if not id say keep the campus tank as im sure there identical to gtt's and that proves not issues 19/gtt
be cool to see, but wouldnt the campus bay need seam wealding, or are they as strong as the gtt?
