Are they going to be part of the site or not?
im sure its a no, there pretty hated across the rtoc.. i noticed even sopme of the more chavvy site are banning them:cool:
I just checked, the animated function is switched on, but the software the site uses to re-size the gif's looses the animation information.
Try uploading a smaller animated gif, it might not need to be re-sized by the site, that might work. Or, if you have software, re-size the one you have already before uploading.
Ok sigs not a problem was just going to write about the services I offer.
What size does the avatar have to be?
Max avatar image is 80 x 80 pixels, try making one 79x79, might not go through the re-size operation then.
Could I have a Sig at the bottom saying something like
www.vivideuphoia.co.uk
Alloy wheel refurbs from £80 other services available to.
Pm or call 07984 761324 for a quote.
Ill try to get a clever friend to sort the avatar lol
Ah, no, sig's not installed, and as a club we've never used them, they wind people up more than are usefull :)
My avatar is now 79x79 but still no movement lol
balls :( Maybe the image gets run through the resize code regardless, I wouldn't know. The problem with installing the other re-sizer is that it's aparantly not as compatable with other images as the default one, so its a loose - loose situation.
Signatures generally suck.
They're only useful on forums where you haven't got a decent profile page... which we do :cool:
