also are the track widths the same on the base models as the turbo models.. (just intersted in the front)
any help appreciated
11 turbos are much wider than 5s ,also anti roll bar is thicker a few mm iirc
thanks for that just in case anyone ever has the erge..
Trackwidths for the front are as follows
renault 11
1394mm - turbo
1380mm - TL
1395mm - GTX
Turbo 2
Rear - 1472mm
Front - 1323mm
Renault 5
1325mm - GTT
1330mm - GTX
Renault 21
1450mm - Turbo front
1453mm - TXE
I'm guessing reason for the difference in track width for each model varies down to the choice of the wheel? I'm assuming hub face to hub face would proabbly be the same on all models?
1994 Twingo
front 1416mm
rear 1374mm
Clio 172 (?)
front 1406mm
rear 1386mm
