just tried starting the car and at first all i got was a click. I turned the engine over by hand and tried it again, it turned over very slowly then stopped. I suspected battery so got the jump leads on the van, again it turned over slowly (little bit faster tho) stopped and then started clicking (quite quickly) from the starter. I can turn the engine over with a 19mm spanner it has good compression but its not seized or anything like that. I suspect the starter as it is one that i got from a breakers untested from a 1.6l 440 (thought that it would be ok as it has a higher comp than the turbo). what do you think dose it sound like starter or something else??:confused:
