Re: downpipe exhaust size
might get a slight bottle necking, but im not sure how much it would effect it proformance wise..
Your using a 3inch 200sx downpipe modded to fit onto your 2 1/2" sidey right?
Can't see a problem with that, most people use a 2 1/2" turbo back system, having the first bit in 3" isn't going to hurt perfromance
yeah will be in 3 inch on the down pipe and il put a reducer in before the cat /decat pipe then it will be in 2 1/2 pipe from there
reevio
As long as the reducer gives a nice clean flow from 3" to 2 1/2" shouldn't be a problem
yeah its a stepped cone reducer nice and smooth and wont have any steps in it as the 2.5 inch and 3 inch step are next to each other also i may put a flexy joint in too just so theres no pull on the turbo from the exhaust system
2 Attachment(s)
u got any piks on what yr down pipe looked like fella
mine ended up like this (see pik)
dont like it tho:(
Dave what the feck is that:wasntme:
dave r5
dont like it tho:(
Is that a divided flange, seperating the wastegate flow from exhaust gas?
i know it dont look pretty but its all i could come up with
it works tho an saw me to 223 bhp granted it only lasted 3 days but boy it was quick haha
yeah it a divideing flange.
the waste gate was atmospericly vented.
it has been re made now tho due to false afr readings
and that it was so feking loud
