Re: 11 turbo leaky sunroof
mine leaks too, and has dropped on one corner? havent tried opening it just incase it drops off or something? duct tape has stopped the leaking tho if thats any help;)
hi mate,
if you're %100 sure that the drain tubes are not blocked it might be the rubber seal around the sunroof.
it's either moved or lost it's sealing properties due to old age.
I hope this helps.
Yeah, it's clearly getting past the seal, I just cant work out how it then gets into the car - that's what the tray is there for, to catch it and let it out via the drain tubes. :scratch:
Big tube of black silicone sealant comes out at the weekend methinks
anyone got a pic of how it all goes together? mines droped in one corner?
How do you mean dropped in one corner? The moving metal roof panel itself?
Which corner?
Some photos of the mechanism dismantled etc in my project report over on Retro-Renault.
http://www.retro-renault.com/forums/...#content_start
cheers will take a look, the passanger side rear of the metal top sits about 1/2 inch lower than the roof?
Well knowing exactly how the mechanism works from having stripped mine down, I think there's only one way that could happen - one of the 2 little runner thingys that is meant to be attached to the ends of the 2 cables has come off.
On my 11's and others I've seen, it's always been the front metal drain tubes on the tray ,that the rubber drain pipes push on to,which rust away leaving any water to drain back into the car,I'm sure you've covered this though!a real pain in the ars*!
hope you get it sorted,my turn next:scared:
Yep, one of mine was broken off, I repaired it so they are all intact and sealed.
Neal 11T
maybe through the outer sides of the seal???
Dont understand what you mean. The seal you're talking about is the one attached to the edge of the moving metal sunroof panel yes?
What I'm saying is that yes, clearly it's getting past that seal, I dont think it was ever designed to completely 100% seal watertight to the roof skin. Just sort of a first line of defence. Hence the drip tray built into the sunroof mechanism, and the drain tubes to let the water that gets past the seal to flow to the outside of the car without entering the cabin itself.
Or am I getting completely the wrong end of the stick?
What I'm saying is I dont know how, once the water drips into the drip tray, it then gets around/out of it and into the headlining, rather than just running away via the drain tubes.
Adey aka Ewok
Adey, I have the exploded diagrams in my old pc somewhere. I'll try and dig 'em up at the weekend and post them here mate.
i l k e r
any joy buddy?
Adey aka Ewok
any joy buddy?
I've found the printouts but couldn't find the pdf file, it must be on one of my backup cds.
give me a couple of days and if I can't find them by then I'll scan it from the printouts.
sure it will, legend cheers
