http://item.mobileweb.ebay.co.uk/vie...d=180688832532
Hope that works if not google the item number please just wanted to know will they fit a renault head/fuel rail as they look different to normal bosch types? Or is it the photo?
They should fit but it says in the add that there 347cc, if that's the case at 100% duty cycle they'll fuel enough for 277bhp but you shouldn't really hold an injector at full 100%, idely you want to run at 80% duty for your maximum power.
What sorta bhp you aiming for?
this has helped alot
http://www.injectorcleaning.co.uk/flow.htm
im going to go for bosch 803's which flow 381 cc's should be enough for 15-18psi as i thought 10 psi years ago was gonna kill me!
James runs 12 psi on 802's (R21 light greens) & coops runs 15 on the same so the dark greens should be ok for you.
