Re: Q's and A's on the volvo
the cooling
http://img20.imageshack.us/img20/9025/koeling.jpg
I have an volvo 240 2.3 rad installed, only problem is that you have to make something up for the thermoswits
http://img517.imageshack.us/img517/489/img1691r.jpg
Ow and the renault engine code is F2N
I'm using a Renault 19 16v rad in mine mate, fits quite well in there too.
I've plumbed mine up like a standard Volvo 480 as my turbo doesn't have water cooling to it, still kept heater matrix though. Its just a case of looping the pipe really if your not using it so it continues the flow round.
How much did those head bolts come to mate, may be interested in a set. ;)
sweet may try an get 1 of those rads then
any 1 have a spare?
the head bolts work out at £2.50 each bolt
im yet to order them tbh just gota make a fone call an its done.
got a few new volvo head gaskets, some slight oxidization on a couple here an there but cleans up with wire wool, drop me a txt.
i torque my bolts to around 73-80 nm depending on the day.
any pics of ya water system? so long as all the pipes are the same temp its should be workin fine, i've done them in various ways
for simplicity a gtt rad is the best, with oil sandwich plate for better than std cooling. 480t volvo rad, clio 16v, clioi/extra/5 diesel rad all work fine to
im using a standard volvo m59, as with anyone elses i've done. think it feels alot more precise than a gtt. have had a few that has ended up with metallic bits in, one the end cap was dented in rubbin on the end gear and the other was the one that was originally fitted to mine with the engine at 130,000miles, bout 20k racked up of hard abuse inc lots of pod visits, gradually increased in whine as the diff was on the way out.
just call if ya stuck :)
