Is there a guide on how to remove the dashboard from the car? I tried searching but couldn't find anything specific
Found loads of dodgy wiring and want to rip the lot out and sort it properly.
remove stearing colom remove speedo cluster. remove centre consil remove A piilar trims remove front footwell trims . unplug the dash wiring. pop back the heater controls
leave wiring loom on the dash
find the srcrews that hold the dash to the heater box and remove
unclip the dash from the foot wells
when its all swinging free unclip the top of the dash from the top and remove the dash
takes me about 20 mins but ive taken a few out:)
Good luck there. removed one on saturday. But wiring was a mess, and wrapped around every item. Main thing is removing all the screws which hold it in place.
Rough idea:
Remove clocks and lower steering cover. Unbolt steering column (4 bolts) 2 screws to side of it hold dash. Undo the wiper and indicator stalks and remove. Unplug all switches and time clock, remove both A pillar plastics, remove centre consol, remove ash tray, lift up flap on dash, remove lower tray bit and undo screw under there. Can remove kick plastics or just unscrew at front, its awkward if you dont remove as need to disconnect the 3 plugs behind each panel and the earth. Behind ash tray there are two plugs which need disconnecting. Use a long screw flat head screw driver and unclick at the sides of the dash, you will see white clips which are easily broken though so be careful with those. There are three clips which run across the top which I am not sure if there is a good technique to unclipping these apart from bashing the dash up to unclip. Might find removing the left air vent you can lift up easier there. Once all those unclipped lift dash forward and you will see the two cables which hold the vent wires in place. Unclip those cables from the heater box. Also there is the fan speed controller as well to unclip. Also ignition wires need removing. Think thats about it. But once you remove the dash out you will see what is left
dale we should have a dash removing race ...lol:)
Ok, well I need to remove the dash from the Raider, I will time you if you can remove it in 20mins and fit in 20mins :) . And sort out wiring. I can remove one very quickily if I dont want to save the dash :) I know you dont need to remove half the stuff, but if you are sorting out the wires and remove the wiring itself you will need to do all that stuff anyway, only ever removed dashes when being replaced :)
It's odd that the heater controls have to be pushed backwards, I spent ages trying to pull them through the front and ended up totally destroying them
Good job I have a spare, but now one of the clips that hold the control cables on has pinged off behind the dash somewhere. Presume you leave those cables on the heater controls and disconnect them from the heater box instead?
Thanks for the guides they are very handy.
If anyone has any pictures of dash removal they would be extremely useful
Some info on the dash board clips:
I took these pictures last night as I was using this thread to help me, pics show the 3 clip locations across the top and the two side clips, one each side.
I found the best way to remove the top clips is to pull out the bottom of the dash a bit insert a long tool like a breaker bar so the end is pushing against the underside of the top of the dash and push up to pop the dash off the clips.
http://i160.photobucket.com/albums/t...37638FD733.jpg
http://i160.photobucket.com/albums/t...37729E9FE6.jpg
http://i160.photobucket.com/albums/t...3788C7A97B.jpg
why are you guys always leaving the wiring loom in? :/
Its so much easier just to unplug it in the sides and in the middle.. and leave the fusebox on the dash.. :)
Cheers for the pics and info.
Not touched the 5 over the winter so when it warms up a bit i'll have another bash at getting it out
I basically didn't realise I could leave the loom on the dash untill I took half of it off. But I had so much other wiring to take out, for gauges and alarm that it made it easier to have the dash out the way anyway.
