******* sleeping policemen!!
:mad: Went over a sleeping policeman at the local supermarket tonight, banged underneath (the usual exhaust scrape) and pulled into to park. came back and now cant get gears! Just wont go in any gear and reverse crunches!! Aint had a look yet but fearing damage to the box or selector..:mad:
Re: ******* sleeping policemen!!
MATT C Ringworm Tuning
Maybe the linkage has just come loose fingers crossed :sos:
you may find out the zorst is pushing on the selector rod making
it difficult to select reverse only (been there ,got t-shirts to proove) :laugh:
should be an easy fix :agree:
:coffee:
I can't get any gears. They just wont go in!
Just sell the car young buy a citroen picasso :cooter:
Just wanted to agree, ********sleeping policemen!!!
Well i cant blame the sleeping policeman as it wasn't the cause and maybe just coincidence. It seemed to be the clutch pedal not adjusting. I removed the block, pulled up the pedal. I could now get gears but the clutch was slipping and biting right at the top due to over adjustment and obviously disengaging the clutch slightly. Blocky set it half way i presume and it seems ok now. I think the quadrant assembly isnt self adjusting??? Anyone had this problem??
I remember a way of how to get the quadrant to adjust again, push the clutch pedal all the way down and release it quickly by sliding your foot off to the side. Do this a couple of times and see if that makes a difference.
