Re: B18FT alternator setup
Im at work now mate but i can put a picture up later if no one replies. I had problems with my alternator mounting bracket and tensioning arm to, they where very close to my intercooler as its a grill mount. I basically took about 15mm of the back of the alternator mounting bracket so it sat closer to the engine then elongated the tensioner arm holes at the bottom to pull everything in a bit closer.
phil
Cut the spade off the loom and put a ring connector on like you say and that goes to +12v then if you're using gtt loom as well cut the double spade connector that went to the top of the old alt and put a spade connector on the purple wire that goes to top of alt, yellow wire gets left alone.
Nice one guys, spot on! :agree:
Just to bring this one back, I'm clear that I cut the spade connector (Volvo Loom) replace with a ring and put that to the +ve connector. Also all the lives on the gtt loom go to the +ve.
Can you confirm if the purple wire goes to the "L" pin on the alternator (botton lhs in the above pic)
The yellow wire (GTT loom) gets left alone...
What about the earths in the gtt loom, do they need to go to earth or just pair them up and leave outa the way?
Cheers...
Earth the gtt loom and yes use the purple wire. You'll soon find out as if you use the yellow the engine won't die when you take the keys out:laugh:
I used the Volvo alt bracket with RSI tensioner/adjuster bracket no power steering bracket attached on the RSI bracket ;-)
