I am installing security system to my car. There several question marks...here is first question mark.
We are speaking now about R11 Turbo.
Where is tachometer signal cabel?
You should try either the "ECU" units middle (if I remember correctly) connector or behind the dash on the clocks. In 5, itīs in the center loom, which comes in the car behind the clocks. I donīt think that there are much differences here compared to 5 in the 11
Any pics that show right wire/wires?
There should be only 2 connectors in use at the RE208/209 ignition unit. One comes from gearbox top, reading the crank position and the other one goes inside the cabin.
http://pquillon.chez-alice.fr/r5gttu...ctions_aei.jpg
