Re: Group A boost hose corks
I'f I fit two will it give me 600bhp?
If you want to go full out, then take your uncut boost hose, chop it into several sections and add a cork or a rusty wheel bolt along with 9 jubilee clips to seal back up again.
You know have a Phil special :coffee:
These are after market only I have the origional :laugh:
Mark you are a :jerkoff:
if anyone is interested these also double as bump stops for old ladies on mobility scooters:cooter:
What vintage are they from ? :D
If these are Prosecco or Cava then they simply won't work above 15psi, the seller should know this. If you're running big boost you'll need the uprated Champagne cork. :coffee:
Trevhib
Lol it's from a Moët rated to hold 35psi :laugh:
seller should also put in the add they are group B fuel tank bungs:smokin:
No address either tut tut come on its classified rules!! :sad2:
Collection from the local bus depot as Phil needs more paint.
car.crash
I always thought he went to the local fire station to 'hang out' with the guys??
I wonder if the cork can be modifed to be used as a bleed screw?
Dave Reed
Yeah, slides up and down the poles..
dangerous dave
:jerkoff: the lot of you :laugh:
dangerous dave
il give you a grand phill if you can slide up one of those poles:wasntme:
HA HA HA HA HA :laugh::wasntme: Quality.
Romil Davda
from what i hear of your engineering skills.... its well possible rom...;):laugh:, damn i need one of theses for the coupe or is that cork...:laugh:
These are a most versatile item .Old boy nextdoor uses them to space his wipers off the screen of his campervan to stop them freezing stuck :laugh:
