F7p - Throttle body to manifold gasket
Can someone please give me the part number for this as needed asap :)
I am trying to get a PTFE one of a bloke on the clio16valve.co.uk forum but he is takeing his time so Renault one will do for now as I need to sort this fecking air leak problem out.
Re: F7p - Throttle body to manifold gasket
James5
I am ring to get a PTFE one of a block on the valver forum but he is takeing his time so Renault one will do for now.
just use liquid gasket or make one from kellogs box to be honest mate :agree:
Schakal
I was originaly just using sealant after I removed the old gasket but I am having a heck of a time trying to find an air leak and am just replacing all bits with new gaskets
:laugh: Kellogs box how good will it actually be if I did that?
James5
Kellogs box will work perfectly well ,its thicker than the standard gasket .
air leak is probably between head and the manifold , spray some wd40 down there
while idleing .if idle goes down thats your leak . also worth checking pipes from/to the
iscv for splits .
