hi there all
is there any difference between the 172 and the 182 cams or the roller rockers?
hi there all
nope, all the same
no apperntly the only main different is exhaust and inlet manifolds
What about cam timings? these the same? and maps?
Yep. Also 172 Ph1 (aka 169) has cable throttle body compared to electronic from 172/182.
See, now you've got my attention. do you know how the inlet differs ?
everything is the same, bar the mentioned above, and ph1 172's have bigger exhaust valves ( apparently )
later inlets have different breather setups and tb setup, also some came with an inlet stamped rs this has bigger ports, the 172 has a 4-1 mani 182 4-2-1, timing is all the same maps are different nowt else that i can think of
Its just that I find it hard to believe that they managed to make 10hp from an exhaust swap. I am led to believe the camshafts are not the same, that could well be B/S.
i dnt think they did make 10bhp more
all sales pitch to make it better than the pug 206 gti 180 that was about at the same time
so it look like the cams are the same though out the clio sport (ph1 172, ph2 172, 182). just been out and measured the valve's in my c/head the inlet valve are 33mm and the exhaust are 29mm.
does any one know any more about the different size valve? i trying to work out if my engine is ph1 or ph2.
thanks guys
you can tell by the number on the block F4R is the engine code for all 172/182's
738 is for the 182
730 are for the mk1 172 (Some Mk1's use the 732 engine with a manual throttle body).
732 is for the 172 Cups
732 and 736 are for the mk 2 172's
Parts are interchangable there the same basically the Mk2 172 has electric throttle bodies so thats there give away. the 182 having its 4-2-1 manifold.
How easy is a Exhaust manifold swap alone on these on a ph2 172 for a 182 mani? ive worked on a few and done cambelts to services for peeps but i got a guy after a mani swap? i duno what to charge as im unsure the lenght of the job and if i need to lift engine out of its mounts for room?
Where are abouts on the engine are you pulling these numbers from on the F4r lump??
on the rear mate, sometimes on the timing belt cover (its a sticker btw)
cast into the block on mine, on the back I think.
Bit of a pain - fitted the 182 manifold, decat pipe and new engine mounts to my friend Neils clio cup 172.
Took me most of a day but the difference is massive! Really revs nice and you can feel the difference in power - torque steer in 1st and 2nd is a lot more.
The clio cup inlet manifolds were hand picked from the best castings and apparently all the clio 172 cups have made the power stated or VERY close.
To put the performance into context a tweeked early scooby (big exhaust / I/C on show) was about half a car behind by 100 ;) lost him on the bends :D - don't tell Neil I was ragging his car though LOL
Clio V6 mk1 airbox to fit when I get time with a cambelt change and full service and pads etc.
You have to drop the subframe ;)
So a full subframe drop to do job? i can see numbers rolling in my head :coffee::) also need to fit a decat at same time but thats not an issue.... does the frame have to come right off all bolts or just back ones and lose fronts etc if you get me?
Ps sorry for hi-jack to thread on this......
It was a while ago now but sure I needed to undo all the bolts retaining the subframe. Not that difficult, just be care full to not lower it too far or the driveshaft will pop out the gearbox :D I did it with axel stands / jacks - would be a lot easier on ramps :) you need a dcat pipe anyway as it will not join the original 172 exhaust.
:agree: cheers duncs...
Right chaps, i just fitted a set of matched ported inlet manifold to a 172 cup yesturday, i think the jan sport jobby. Now the mani i removed was the RS type, and i could hardly tell the difference between the too IMO. Anyway there is a £60 surcharge on the mani so is it worth swaping for the cash with jan or keeping hold of or are they worth more on ebay?
Also while on the subject are net cams (if i heard right) any good??:confused: seem cheap, if not witch is an ideal cam to go for of the shelf.. Im getting asked to do these jobs but i dont hold very good advice on these motors yet...... cheers :agree::)
net, not cat, or web?
From what I have been reading on Cliosport.net the RS type are fairly rare and are supposed matched / better ported than the rest.
i think 172 cups had the rs inlet an dthe last of the line 182s and trophys did too
could the difference's just be BS ? sounds like potential BS to me. Rob, sounds like you need to swap that manifold with a standard 172 one I have under the bench, I'll tell you if it's any different :D
ive seen a stock bottom half and an rs bottom half side by side, defo a difference:agree: cant comment on the top sections tho
