16" Speedline Turinis from 172 Cup
Guys, will I get 16x7 Speedline Turinis onto my phase 2 GT Turbo without too many clearance issues?
In process of selling my Clio 182 and will have these wheels left over.
P.S. I did search but couldn't find any threads on these or standard 172 wheels.
Re: 16" Speedline Turinis from 172 Cup
Depends on the offset. I know the trophy turini's were a different offset, but i'm guessing you probably have the cup ones which will sit in the arch more.
I ran 16" 172 alloys but you will defo need 195,40,16 tyres.
if they sit in too far, you can always run a 5mm spacer to get them out further.
Thanks for the responses lads.
Fairly sure they're from a Cup, I will double check them.
Bugger if I have to change tyres as they have a set of 195/45/16 Toyo R888s on em with light wear.
Mine are cup rims and fit ok,menu 5mm spacers on the front with 205/40/16's
https://www.rtoc.org/boards/showthread.php?t=29373
They should be ET38.5 if they are genuine 172 cup Turinis.
Trophy Turinis are ET43
