Hi
Any advice over removing the external (roof side) sunroof surround? The Brittax type.
Are they sealed to roof skin with a similar sealant windscreens are bonded with? Surround is corroded and needs powder coated.
Hi
I have an aftermarket Britax sunroof and I've been strongly advised by my
resto guys to leave it in place. It too is corroded, but apparently it'll be easier
to rub it down and give it a coat of Plastidip than remove it. The metal roof is
so thin you are very unlikely to remove it without causing permanent leaks
after refitting.
The choice of Plastidip allows it to expand / contract at will without cracking.
With Season's Greetings,
Steve
Thanks,
Interesting one might just investigate repair in situ. Caused enough damage removing the windscreen myself!!
Tom
Does the sunroof leak? Mine was removed when the raider was re-sprayed in 2006, however they just bolted the sunroof back to the roof skin so after having the car back a couple of weeks and it rained water was running in! :eek: :cry:
So, I bought some windscreen type sealant stuff and sealed the sunroof frame to the roof skin, the sunroof opening lid was sealed shut by a windscreen company previously.
The sunroof frame on my car is corroded, really tempted to get it removed and a plate put over the top however would not want to distort the roofskin whilst removing it incase it is sealed/stuck fast to the roof skin. Plastidip sounds like an option. ;)
The frame is badly corroded in one area, first preference would be to remove it. Then replace or powder coat, its not looking great.
Distorting roof skin is worry, although sounds like your paint shop removed ok?
One of the guys in the club replaced his roof to get rid of his sunroof. If you go this route, make sure the replacement is from a three-door!
