I suspect my standard turbo t2 is fecked. When we pulled the engine out the Volvo there was signs of a bit of oil in the pipes. I did have a t2 given to me with the car, but did not fit that one and stuck with the one of the engine.
Since running the car in i have been taking it slow, but have noticed my car only running 4psi i tried to put the boost controller on to increase boost a little, but got no increase at all. Gary then mentioned i may not have enough load on the actuator. I took of the clip and closed the waste gate and the rod had sufficient on it to just open the actuator a bit, nevertheless i turned it a few more turns to shorten the bar, probably another 3-4mm.
I thought it best to take of the boost controller as i have no idea how far in or out it should be wound and do not want to blow it up.
When taking the boost controller off i noticed oil in the vac pipes so im guessing its being pumped through the vac outlet out of the turbo.
This must not be normal, what do you reckon guys, it would explain why the boost would not rise when i tried to increase it. The car does not smoke on tick over or even driving it :confused:
phil
