Clutch &or Cable Problem Or Something Else....?
as some of you know im trying to get to the bottom of why my car isnt boosting.
anyway,
i had a problem with my clutch pedal rachet being worn, so i have replaced it with a good one.
i then routed the clutch cable through the white piece on the pedal and then through the black toothed piece..
i then removed the pedal stop... then depressed the pedal and then let it come back up. i heard a few clicks so i refitted the pedal stop and pressed the pedal for a 2nd time. job done.
i proceed to take the car around the block to check on the boosting issue and the car changed through the gears as you would expect.....
then when on my way back to mine i went from 1st to 2nd but could not get 2nd...or any other gear, i couldnt even put it back into 1st.
i got it home and did the pedal thing again, took it out and it was fine..... then again on the way back the same thing happens..no gears:scratch:
the cable isnt a genuine renault but an aftermarket one. its slighly loosISH on the clutch fork.
do you think its the cable thats causing this?
Re: Clutch &or Cable Problem Or Something Else....?
Fit a genuine cable mate, that will sort it. Sounds like the clutch cable is too long. I had to bodge a spacer in with one to make it work, the aftermarket cables are crap really.
Also leave the stop in place when resetting the ratchet.
Deffo clutch cable Raj. The cable should have a decent amount of tension when not pushed
ok, ive got a new genuine cable here.:agree:
so any tips for fitting the clutch cable when the car is not in the air?
i know to tie some thread to the cable before i remove it from the footwell, then tie the thread to the new cable and pul it back through... but its just that plastic bit that you have to push fit into the footwell that annoys me.
it should push itself in when u tension it mate.
if the genuine cable doesnt sort ur problem out ,then just put a washer or 2 over the cable before u put it through the bulkhead!
update:
fitted a genuine renault clutch cable today:agree:
now i havent actually drove the car as such since fitting it, but i drove it back and forward off the drive.
think is, it sort of feels worse than the non genuine cable:scratch: when i press the clutch pedal down,it gets to about half way down and then it feels like it looses tension. its that poppy clutch feel. now im sure ive heard it mentioned that the valeo clutches do this??
also the biting point is very near the floor,which doesnt feel right to me!
also after my bro pulled the cable over the clutch fork "which he said was pretty hard to get over the fork"while i pushed the pedal rachet towards the bulkhead and then pressed the pedal a few times, the cable still kind of feels loose at the fork end:scratch:... i mean i could pull the cable back off the fork without applying to much force.
doesnt sound quite right to me:scratch:
is the clutch cable routed a specific way?
ive routed mine from the fork to 1 clip on the chassis arm(i think there are 2 clips on the chassis arm but i snapped one), then from the clip to the next clip which i thin is located on the subframe near the rear engine mount... from here and around the steering rack boot and up through the hole into the drivers footwell.
it doent matter where u route it mate, mine is the same, u can pull it off the forks really easily and the biting point is on the floor. if u dont like it put a washer or 2 over the cable end before u feed it through the bulk head
kinzx10
well im not going to remove the cable again thats for sure, it was a pain fitting it anyway:crap:
if thats the way the pedal is supposed to feel i suppose ill have to stick with it:crap:
how new is the clutch itself ?
also the clutch fork pivot bush could be worn inside the gearbox .
small play at the bush will magnify itself at the top where the fork is
being pulled .
Schakal
being pulled .
the clutch is new,its not even seen 20miles yet.
right,
i still havent got around to sorting this clutch problem:sad2:. bare in mind that the car isnt taxed and have only been using the car on a private road to check this issue.
can anyone confirm they have also tried the "put a washer over the cable before you feed it through the bulkhead" method? as mentioned above?
im want to get to the bottom of this.
why is it that the cable is still loosISH.? i can easily enough slide the cable off the folk(it doesnt litterally slide off, i have to grip it a pull it off but its easy to do so) and slide it back on again.
- the clutch fork is nice and solid without the cable and with the cable attached.
- the cable is a new genuine renault.
- the clutch pedal/ratchet bits + bump stop have been replaced.
so at what point is the cable loosing its tension?:confused:
is there anyone local willing to come and sort this out for me?
im really not a fan of fitting things twice only to be told i may have to remove it again:sad2:
bump.
come on folks,
i cant figure this out alone:scratch: someone must know a 100% sure fix for this.
again bump:rolleyes:
im stuck if i cant get this sorted. its the only thing left stopping me from taking the car out:crap:
Can only think your cable is not routed properly Raj. I have the thicker cable from cgb which had the same problem as your having, instead of finding out the proper reason for it's looseness I choose the quick fix method with washers. Snip some washers bend them so you can thread the cable through them then rebend them back into shape. These will sit on the gearbox fork and create more tension.
TrixNFlix
We are having the same problem with Chris's aka fidos got a raiders gtt, we have about 4" of slack with a brand new Renault cable :confused:
TrixNFlix
ok so thats the quick fix washer method. but i really do want to sort it out properly, im not keen on quick fixes only for them to show there ugly faces again.
James5
4" of slack! thats alot.
with mine i can move the clutch pedal about 1/2" before you even feel any sort of tension.
and at the clutch fork end the fork itself is pretty solid,with just a very slight bit of movement, i can push the fork towards the engine ever so slightly(estimate about 2-3mm) its not even noticable. and i can slide the cable off the fork quite easy
raj
I've done 1300 miles with no problems, so no ugly faces for me. :p
Inside the gearbox where the clutch fork sits there is a metal nipple (ooo err!)
On said metal nipple should sit a white plastic cover/tab/bush whatever you want to call it. if this is either missing or worn you will get the feeling on the clutch pedal your talking about.
I know this as I forgot to fit my new one when I was re-assembling my engine and gearbox and I didn't realise untill I had the very issue your talking about.
I just shimmed the cable where it goes through the fork as i couldn't be arsed to take it all apart again.
I then fitted a new clutch a year or so later and replace said bush and bob's your uncle the cable didn't need shimming:)
GTphil
how exactly do you shim the cable where i goes throught the fork?
id rather do something at the fork end as apposed to putting washers over the cable before pushing it through the bulkhead.
do you have any pics of what was done at the fork end? im crap if i dont know what im doing without visuals:crap:
No pics I'm afraid:(
All I did was disengage the cable at the pedal end so it went slack. Then put the shims (I used some big washers that I cut a groove in with a grinder) on the side where the cable is held in place, the one with the stop.
Then re-engage the clutch cable and all was well.
I used about four quite thick washers:)
:edit: Plus you will have an ajustable bite point if you do this! lol More washers = higher bit point!
just wondering, with the washers fitted against the fork in the dip/groove where the cable would usually sit,would this no cause the cable to sort of work its way off the fork.?as it would no longer be sitting IN the dip/groove.:scratch:
Mine didn't. You can only try!
im sorry i do giggle when i see threads like this . no disrepect :p
THE MASTER
colin giggle on:cry: its annoying the hell outta me.
as your giggling i can only assume you know how to fix this problem:uhhuh:?
if you've got another way than whats already been mentioned please share it.?
I think gtphil has hit your problem on the head. :agree:
raj
Loads of slack unfortunatly, we have replaced the following - engine and clutch (Due to other problems we took the easy option :D ) clutch pedal, clutch pedal spring, as said the cable was a new genuine Renault clutch cable, routed correctly, the fork is not bent, it sits on the clutch release bearing properly and the gearbox pivot bush appears in very good condition.
Now the the 4" slack is weird and i very much doubt this much slack would be down to the gearbox pivot bush all I can think is the cable has stretched somehow, or it is not routed correctly. I have looked at my 5 and the routing is identical to mine :confused:
At present this the only thing stopping the 5 from being driven. I am going to get the 5 owner to get another brand new Genuine Renault clutch cable and started over again.
At some point, we are gonna have to start measuring these different clutch cables :)
GanJaMan
That was my next thought seeing if someone had measured a brand new Genuine OE clutch cable?
I am seriously considering cutting down the orginal cable and PMT modying it together so it's useable.
:mad::mad::brickwall:
This is REALLY testing my patients now.
ive been out to slip some washers inbetween the cable and fork, i started off with 1 washer with no luck, then 2, then 3, and then i realised i could actually pull the clutch cable pretty far away from the fork towards the drivers side:scratch: now i wasnt going to try and fill that space with about 4" of washers:scared: plus the fact that if i put more washers on,the clutch had that horrible pop feel to it..you push the clutch pedal and as you get to half way the pedal drops to the floor like it lost all tension. at least without the washers it felt pretty much the same throughout.
im sure if i remember on all my previous 5s it would be very hard to even pull the cable away from the fork! i just dont get it.
my cable is routed from the clutch fork, it runs over the turbo oil rtn pipe, then it clips to the chassiss arm, it then runs to the clip behind the rear eng mount and then it goes around the back of the steering boot and up into the hole in the bulkhead. IS THIS RIGHT.?
the clutch is new.
the clutch pedal/ratchet is a 2nd hand one from mike phase i 16v as my original one was knackered.
:scratch::cry:
i got a simular problem but instead of using washers i cut an old socket length ways but still the same, so going to cut another socket up just going to use a longer 1 this time
modfather
the thing is we shouldnt be needing to do these daft mods:sad2:
im not impressed thats for sure!
im hoping to crack it tomorrow, really want to get out for a blast in it, i let you know how i get on with it
raj
the clutch is new.
:scratch::cry:
Your at the same place I am with fidos got a raiders car it's doing my fecking head in :mad:
James5
as spacer I have been using old driveshaft knuckels from fecked old drive but as raj says I really don't want to take up 4" of slack
as anyone measured up a new clutch cable yet? Has anyone measured up one that was working fine? ( maybe someone whom is doing a resto of there 5 so being stripped down)
would it not be better (if shimming it) to shim it at the gear box bracket end rather than the fork as like mentioned there is a divit in the fork to hold the nipple in place. whats the big rubber block with plastic around it that sits on the gear box bracket look like? also dose the bracket on the gear box its self look ok?
Raj....check this out.
where the inner cable goes into the car, it should go through a loop on the upper quadrant, if it doesn't and yougo round the side of this, then you will get all sorts of problems.
SCHWARTZ
That's were I have been using my knuckles spacers and I have made sure tha cable gies through the loop as sparkie has said aswell :confused:
is that 4" slack with more than one cable than james?
Sparkie
yes thats checked and checked again, the cable goes through the loop on the white quadrant and then onto the black toothed piece.
im starting to think it maybe the clutch pedal again, as i had i slight feeling earlier when pressing the clutch pedal down it felt like it skipped a tooth and then caught on.
SCHWARTZ
Hi Gary, Yeah matey thats the orginal cable and the new Genuine Renault cable, we had them side by side before I installed the new one and the length appeared identical :confused:
Do you have your cable lying about anywhere that Chris could try out?
Sorry Raj don't mean to takeover your thread, we seem to have the same problem.
:( Very strange! Could the cable be from another modle and sold as a gtt one by mistake?
Seems odd you both have the same problem:crap:
James5
we are sharing the same problem so no worries:agree: its better than cluttering the board with threads asking the same thing:)
we just need to get to the bottom of this PROPERLY:agree: without using bodge methods:disagree:
im assuming the white teflon bush is ok that the clutch fork pivots on? they do wear out....
Sparkie
its been a while since i took a look at it but i do actually remember checking it over at the same time as checking 2 other gearboxes. i took all the teflon bushes off them all and fitted the smoothest one which did even seem to be worn to my current gearbox.:agree:
i could possibly double check this, but is it visable thought the fork gap on the gearbox?
lets see if i can solve this
first thing to check is how does the pedal feels, it should have a bit of free play at the top and is usualy slighty higher than the brake pedal about 1/4 inch to 1/2 inch.
if this is incorrect check that the stop is in place and it lines up with both of the auto ajusting quadrants
the pedal should only move side to side a bit if its floppy cheack the mounting pivots the bigger bush goes nearest the brake pedal.
the route of the cable goes from the pedal making sure that it runs through the loop on the white cam on the pedal then straight down and round the back/rear of the stearing u/j~boot then along the subrame just above the anti roll bar then along the n/s chassis rail and on to the box.
when everthing is fitted and inplace have a look at the pedal the cam should be sitting at about half way on its teeth. ;)
THE MASTER
:agree:I can confirm that Chris's raider is as you have said above routed correctly (as you have said), pedal bushes are good condition and correctly in place, it does sit slightly higher than the brake pedal aswell. The Teeth are in good condition but we still have this 4-5"s of slack. We are going to try another new OE cable
THE MASTER
yes the pedal has about 1/4" of free play, the pedal sits abit higher then the brake pedal:agree:
THE MASTER
the pedal should only move side to side a bit if its floppy check the mounting pivots the bigger bush goes nearest the brake pedal
yes this is all in order:agree:
THE MASTER
yes correct:agree:
THE MASTER
i will confirm this in a few hours.
James5
can you measure the one you remove aswell as the new one you fit please?
raj
