RSC Suspensions / Swiss Made High Performance Coilovers
Re: RSC Suspensions / Swiss Made High Performance Coilovers
Details of the production:
MRS3 Camber Plates and other parts:
http://imagizer.imageshack.us/v2/640...631/Bcm4hr.jpg
Adjuster:
http://imagizer.imageshack.us/v2/640...909/7kVgpC.jpg
Snapshot from the kitchen ... And also for those who do not believe (can) we develop themselves.
Of course I don’t think it is so important that the snapshot is blurred...
Here the construction from MRS2 and MRS3.
And it was important for me, that the hysteresis adjustment will be possible without expansion of the damper.
Lying under the car you have still, but the robust, larger adjuster to the piston rod around will be able to find.
Damper eyes in rubber or unibal, let's see. At the rear axle not so important. And of course, adjustable length:
http://imagizer.imageshack.us/v2/640...913/Wo5WvZ.jpg
And the front axle brackets (damper holder below) in high quality titan- aluminum for MRS2 and MRS3 are back from the production:
http://imagizer.imageshack.us/v2/640...633/OHjd4A.jpg
Adjustable front axle camber plates development. All in high quality titanium aluminium:
MRS3 fully developed.
R5 GT Turbo / GTE:
http://imagizer.imageshack.us/v2/640...661/M4mkXI.jpg
CRS3 -2009 & 2010- / CRS4 2013- (All in one piece! Only at RSC Suspensions!):
http://imagizer.imageshack.us/v2/640...538/Hh9xVu.jpg
MRS2:
http://imagizer.imageshack.us/v2/640...537/qBFRuM.jpg
Development fully adjustable MRS3 Conversion Kit for factory option Öhlins® / Öhlins® Trophy.R. has begun:
http://imagizer.imageshack.us/v2/640...909/RVnwnC.jpg
http://imagizer.imageshack.us/v2/640...673/MOM8Db.jpg
http://imagizer.imageshack.us/v2/640...537/FE0nWL.jpg
Adjustable stabilizer bars for MRS3 now available:
Left OEM, right RSC Suspensions:
http://imagizer.imageshack.us/v2/640...908/6L5I7v.jpg
RSC Suspensions could win WD-40 as a technical partner!
For care and protection is a can of WD-40 Classic with each RSC suspension coilover included.
RSC Suspension is looking forward to a successful partnership!
http://imagizer.imageshack.us/v2/640...904/Tap5og.jpg
Looks like some quality suspension, but if you made uprated rear torsion bars for the GT Turbo you may get some interest? Depending on price too.
Look to be great quality! The 5gt is definitely missing out on a decent coil over kit.;)
Woznaldo
thanks!;)
yes the absolute perfect way would be to develope new torsion bars. i'm in agreement with you.
but that's very consuming. and the required unit volumes immense. and how much you willing to pay?
that is the reason, that is attempted, to cover up / bridge the rear suspension with actually too hard shock absorbers.
the simplest possible solution.
therefore, on the rear axle, I want or I can't for cost reasons for the customer, develop other torsion bars, including the stabilizer bars. it would be nice.
so for the rear axle, I don't want to reinvent the wheel and I offer for the rear axle of the r5 and clio1:
-nothing, use the original shock absorber (light version)
-shock absorber with fixed groupe n set up and bushings, optional with unibal (best compromise, street, racing, country road, alps, nürburgring) (pro version standard, with unibal option)
-shock absorber with fixed groupe a set up and unibal (very hard, absolutely (grand prix) circuit) (pro version optional)
Matt Cole
Matt Cole
Also are you saying you have developed an R5GTT coilver set? We would be really interested in a look at this as there isn't a great range for the 5GT.;)
for the r5 and clio 1 there's anything at the front axle like the current brothers:
full adjustable m52 monotube shock absorber
adjustable unibal camber plates (only r5)
adjustable camber with a long hole in the bracket below (all)
rear axle:
see my answer above.
please check out all informations in the pdf downloads in my first post.
Arno, I completely understand. I have tried to have some Torsion Bars made in Australia and it was going to cost A$1200 (GBP600) for one set (no roll bars).
Are you able to adapt any of the designs you have? The reason for asking is that I want to run the Front Hubs from a Clio2 172 on my R5 GT Turbo. I will also fit the 172 Wishbones (A-Arm/Control Arm) which will increase the track width and therefore the effective King Pin Inclination (KPI).
It might be as easy as using the Clio2 172 Coilover with some light modification to the Hub Attachment Brackets?
I'd be interested in your opinions on this.
Woz
Taken from the price list PDF above are the following prices for GTT suspension:
RSC Competition Pro (with rear spring, rear damper & unibal- camber plates - stabilizer bars & custom color with surcharge) 2080CHF (£1418).
RSC Competition Light (without rear spring and/or rear damper - unibal- camber plates, stabilizer bars & custom color with surcharge) 1690CHF (£1152).
Seeing the quality, I can understand why the price is at the high end of the market. :agree:
I used www.xe.com to do the currency conversion.
Woznaldo
Woz
yes, this cost for new and other torsion bars are realistic...
to adapt a r5 rsc competition with clio 1 front axle parts is absolutely no problem.
only the under bracket must exchanged against the clio 1 version.
the rest of the height can be adjust with the damper length in combination with the bracket.
and the price is the same of course. I need only a info with the order, if that comes into question for you.
Trevhib
I used
yes of course, my target was also to develop something that fits into a market gap.
and this includes a coilover with the latest and best technology also for youngtimers.
there's no point, equal to develop, as there are already and to bring to the market.
there's already enough....;)
Today was Japanese- / All Brands- day:
This gives Honda Civic Type-R FN2:
http://imagizer.imageshack.us/v2/640...537/473oRD.jpg
Here Nissan Skyline GT-R:
Already alone the lower bracket in titanium aluminum in two-piece is a small masterpiece:
http://imagizer.imageshack.us/v2/640...540/GKJIXl.jpg
What is the price for a simple coil over kit front and rear for the 5gtt shipped to UK?
New:
Complete All Brand Application & Price List 2015 now available:
Product overview – PDF Download:
EN:
RSC Competition Renault Sport Application & Price List 2015:
http://www.hostarea.de/server-03/Maerz-201fe3b1fe.pdf
RSC Competition All Brand Application & Price List 2015:
http://www.hostarea.de/server-03/Maerz-c924078da4.pdf
RSC Suspensions Data sheet 2015:
http://www.hostarea.de/server-02/Februar-05953fc81e.pdf
DE:
RSC Competition Renault Sport Verwendungs- & Preisliste 2015:
http://www.hostarea.de/server-03/Maerz-1efade3082.pdf
RSC Competition All Brand Verwendungs- & Preisliste 2015:
http://www.hostarea.de/server-03/Maerz-11bbd354ae.pdf
RSC Suspensions Datenblatt 2015:
http://www.hostarea.de/server-02/Februar-63d6787711.pdf
RSC Competition Renault Sport Flyer:
http://www.hostarea.de/server-10/Oktober-d4ceea8c25.pdf
RSC Competition All Brand Flyer:
http://www.hostarea.de/server-10/Oktober-4ceff1787c.pdf
Fordy
You can see all informations and prices in the new downloads above, I have just posted.
For shipping to uk, I must check it out first.
Depending on the desired version (light / pro / light with unibal camber plates / pro with unibal camber plates),
I can still give you a discount, or shipping to uk for free.
So clear is: The greater the value of the goods is, the greater the discount... ;)
Re: RSC Suspensions / Swiss Made High P1890chferformance Coilovers
rsc light, is this only front struts and camber bolts? 1690chf or 1890chf? 2 pdfs show different prices?
If so @1890chf thats £1275 before shipping etc for 2 front struts and camber bolts :eek:
They'd have to be lifetime warranty against any defects even corrosion, and able to be rebuilt.
They look lovely but how do they perform? Any shock absorber comparison tests carried out?
We already have some decent suspension brands about in the uk for around half the price.. I need more than good looks to consider that much money :confused:
chf 1890.- the front coilovers and camber bolts (light)
chf 2280.- the same with rear dampers (pro)
chf 2280.- + chf 590 for the pro version with camber plates
chf 1890.- + chf 590.- for the light version with camber plates
yes, the perform very well.
target market is between kw clubsport and kw competition. but more at kw competition.
better than biilstein, h&r and similar öhlins.
and the quality, look and performance is equally the same. fits together!
we sponsor this year a mrs2 at the rcn challenge nürburgring and for next year a audi s2 quattro for the timeattack.
Just in: Embroidered RSC work overalls and beanies in different colors and each with two lettering!
Want to have? Order under info@rscenter.ch! ;)
http://imagizer.imageshack.us/v2/640...538/i5fmZu.jpg
Fordy
There's a huge range in price and performance for suspension. Raceland make cheap and cheerful range and then you have high end manufactures like Ohlins that make kit for WRC. WRC is about 10,000 pounds a corner!
I guess what I'd like to see is a customer review against something like KW V3 or similar. Th biggest problem with the GTT is finding a manufacturer that caters for high end on a GTT. Another question is whether anyone wants to spend that kind of cash on a GTT?
I got some MCA Blue suspension for my WRX and the difference was profound!
Yep, this is absolutely high-end gear. As a punter, you pays your money and takes your choice. If you're not in the market for diamonds with the requisite money, there's no point complaining about the cost of diamonds!
Woz is right, the only thing missing here is performance comparison (and ideally somebody who has had this stuff in their hands to be able to better ascertain comparative quality with the other high quality kit).
Do you have any pictures of a kit that is for a 5 GT Turbo? Qty does appear high standard. :)
Goobie, the top few pics are for Clio Williams. They would near identical to GTT items.
yes it's a high quality product, not only in the materials, but also in the set up and performance.
and seen as a whole, it is not too expensive. still cheaper than a Öhlins, or a competition of kw.
but just as good, or even slightly better.
I haven't got compare in gb. Here in Switzerland have been going some r5 clio 1 and the newer models anyway.
yes, the picture for r5 gt turbo is similar.
except the r5 has unibal camber plates as option. and the color is grey/yellow.
The development of the RSC Competition Öhlins® Front Axle Upgrade Kit for the MRS3 is almost finished:
http://imagizer.imageshack.us/v2/640...538/W38CAb.jpg
Got to admit guys, if they perform well then that's the ultimate suspension setup? Thing is I'm looking for a road set up that performs half decent on the odd track day. Plus they need to cater for the heavy engine and box I have up front.
So is there a set up for a 5 GT Turbo, if so how much, does look good, anyone thinking of trying them???
Lol. All of those questions already have answers in this thread :D
Lovely they are!:hump: Tempted to get a megane to fit them on!:D
RSC Competition rear damper with Groupe N set up for Renault 5 GT Turbo for the Coilover Kit RSC Competition PC405-RS in the standard color grey/yellow:
http://imagizer.imageshack.us/v2/640...909/cQHHUV.jpg
It's great to get some feedback from an owner that uses their car on track. Did the owner improve track times?
An improved track time is not necessarily the only indication of a good setup. Consistency is one of the better indicators that the setup is working well as it means the driver feels confident with the car and is able to maintain momentum. It's also a good indicator that car is predictable on the limit.
yes, exactly. you're right!
it was at the eastern weekend and it was saison opening.
very many cars on the track, a lot of traffic.
a meaningful measure time was impossible.
From the production there come slowly more Renaultsport specific parts / innovations,
and I reached into the boxes in advance for urgent delivery
The newly developed fully adjustable monotube damper for the rear axle MRS2 / MRS3:
http://imagizer.imageshack.us/v2/640...537/bwVfEl.jpg
The bump / rebound adjustment on the piston rod of the newly developed MRS2 / MRS3 dampers. Without expansion of the damper possible:
http://imagizer.imageshack.us/v2/640...537/udq7he.jpg
The camber plates CRS3 Ph1 & Ph2. Both holes variants on the same camber plate.
The RSC Competition suspensions for CRS3 can therefore always be used for all CRS3 and an exchange with one another is always possible:
http://imagizer.imageshack.us/v2/640...905/nQxkzh.jpg
Camber plates MRS2:
http://imagizer.imageshack.us/v2/640...673/JdjZyP.jpg
http://imagizer.imageshack.us/v2/640...909/FxmRPW.jpg
Rubber bearing for the rear axle damper brackets MRS2 / MRS3:
http://imagizer.imageshack.us/v2/640...908/jPADP6.jpg
Rear axle damper bracket parts. They are assembled after anodizing, and even pressed the rubber bearings:
http://imagizer.imageshack.us/v2/640...540/OQNthH.jpg
Upper / under spring brackets MRS2 / MRS3
http://imagizer.imageshack.us/v2/640...661/mScA1a.jpg
Stabilizer holder M10 for several RS models (MRS2 / MRS3 / CRS3 / CRS4 / TRS2 / RSV6Ph2)
http://imagizer.imageshack.us/v2/640...537/BNYXUp.jpg
Several front / rear racing springs:
http://imagizer.imageshack.us/v2/640...538/pNzrgV.jpg
Renault Sport Mégane R.S. Trophy 275 with the RSC Competition Öhlins® Front Axle Upgrade Kit inside vs. Porsche 997 GT3 on the Circuit Spa Francorchamps:
https://www.youtube.com/watch?v=zNXALG9_tSY
Some aluminium parts back from anodize:
http://imagizer.imageshack.us/v2/640...911/fpxVyR.jpg
Assembling:
http://imagizer.imageshack.us/v2/640...911/ogH1LD.jpg
http://imagizer.imageshack.us/v2/640...905/IJz8CX.jpg
Assembling: Renault Sport Megane 3 R.S.:
RSC Competition PDZ1N-TR3 Trophy Special black/red:
http://imagizer.imageshack.us/v2/640...540/VooZ4g.jpg
Assembling: Renault 5 GT Turbo:
RSC Competition PC405-RS / grey/yellow (RSC Suspensions standard color):
http://imagizer.imageshack.us/v2/640...538/NPDBA1.jpg
Assembling: Renault Sport Megane 2 RS:
RSC Competition PCM0M-R26R / R26R Special white/red:
http://imagizer.imageshack.us/v2/640...661/zQBxCB.jpg
Assembling: Renault Sport Clio 3 RS:
RSC Competition PCR0N-RS grey/yellow (RSC Suspensions standard color):
http://imagizer.imageshack.us/v2/640...911/FkLOeR.jpg
RSC Competition PDZ1N-TR3 / Trophy Special yellow/red:
http://imagizer.imageshack.us/v2/640...540/kFcPAM.jpg
RSC Competition PCM0M-R26R / R26R Special black/red:
http://imagizer.imageshack.us/v2/640...661/6wTPTX.jpg
RSC Competition PCM0M-RSC / RSC Special orange/grey:
http://imagizer.imageshack.us/v2/640...538/cp5f8r.jpg
RSC Competition PCM0M-RS-NR (Nürburgring) / grey/yellow (RSC Suspensions standard color):
http://imagizer.imageshack.us/v2/640...673/3tHHVy.jpg
RSC Competition PDZ1N-RS grey/yellow (RSC Suspensions standard color):
http://imagizer.imageshack.us/v2/640...633/3G6n6E.jpg
RSC Competition PCR0N-LF1 / Lotus F1 Special black/yellow:
http://imagizer.imageshack.us/v2/640...540/b0qili.jpg
Very nice Arno, keep the pics and info flowing :)
thanks! ;)
yes, at the moment i'm very busy with my brand. and every day i have more news... ;)
RSC Competition PDZ1N-TR3 Trophy Special yellow/grey:
Rear axle parts:
http://imagizer.imageshack.us/v2/640...538/3Yy9nE.jpg
http://imagizer.imageshack.us/v2/640...908/CZmfHi.jpg
http://imagizer.imageshack.us/v2/640...537/HVP3K0.jpg
Rear axle:
Hardness adjustment:
http://imagizer.imageshack.us/v2/640...673/41lmnd.jpg
http://imagizer.imageshack.us/v2/640...540/GrYCsS.jpg
Front axle:
http://imagizer.imageshack.us/v2/640...673/IRZjo9.jpg
Front axle:
RSC Competition PDZ1N-TR3 Trophy Special yellow/grey & RSC Suspensions Stabilizer rods KDZ1N:
http://imagizer.imageshack.us/v2/640...911/DFjie3.jpg
http://imagizer.imageshack.us/v2/640...901/Fent1F.jpg
