5teve L
Ok, today took engine out, split it, found the problem... stupid dowel on the back of the gearbox :scratch: can't believe it would lock the engine but it was.
Engine back in, wired up just need to charge the battery as my pack was flat as well, but car cranks ok. Need to get a throttlebody adapter plate, split the drivers ball joint & pop the driveshaft onto the box, crank it for a bit longer to get the oil pump primed & then fire it up & watch it smoke like a biatch..
