formerly known as "The Rainbow Warrior"
I guess I should start a build thread, and I'll start will a really dull entry :sad2:
For this first little job I'm converting the front hubs to use studs rather than bolts. The studs are Ford fitment from Rally Design. I'm using early 4 stud Laguna 2.2D hubs, and they're a fair bit chunkier than the GTT ones. In the attached pictures I'm thinning down the front hubs, partly to lose weight, partly to give some space for the studs, and partly to set the right length through the disk, wheel, and new front nuts.
My lathe isn't very big, and the drive belts were struggling with the large diameter steel so I ended up having to take 10 thou cuts, that's a lot of cutting, and I filled a bucket with swarf.
My next jobs are to drill out the original threads to 1/2" and press the studs in. In the background of the 3rd pic you can see 2 studs partially screwed into a 3rd hub. You can also see the thinned down hub alongside an unmolested one.
