TNT!hammond
update ,
fitted a t25 which is a tomcat core and front but with a .47 rear machined housing.
went to do a few runs but after only 2 it started raining, i can say the temps seem lower from the cooler on boost @ 18 psi than before but after around 5 k start climbing again at pace to around 70 'c , this is hot but better than 90 hahha.
going to do a few more test tommorow, unfortunatly i couldnt get another gauge and sensor to test the one i have so this may have to wait. I am also worried now that maybe i have high egt temps causing the turbo to heat up and transfering heat across.
Ill check my timing tommorow just to be sure im not running silly advance or something?
