Hi guys, not new to building car projects albeit it the others are usually on larger budgets and invole lots of paint polish and expensive parts, where as this one is designed to be more function over form , so i have a car i can park in rough areas without worrying about to much, although ive never really had a play at all going sideways, i wanted a cheap winter motor , and stumbled across a cheap s14a with tax and test, it has 3 rusty arches and isnt exactly pretty, but its 100% standard, unlike most of them which often seemed butchered , which isnt a problem but generally the quality of the work sucked.
Anyway, another problem this was had was a boost leak, a big one.. as such i me and chidley on here fitted a front mount last night which seems to have solved the problem, the standard wing mount intercooler feel apart as i tried to unbolt it.
One question is, its of my understanding the bost solenoid that sits on the passenger side wing detects for knock , and also ups the standard wastegate boost up to 10psi from 7. I wasnt 100% how to re input this into the circuit after we did away with the carbon canister etc during the front mount install. Does it just sit inline between the turbo actuator and the cold side of the intercooler ?. and if so which outlet goes to which.
Standard before we begin
http://i3.photobucket.com/albums/y98...IMG_3628-1.jpg
http://i3.photobucket.com/albums/y98...r/IMG_3629.jpg
the blurred remains of the standard intercooler
http://i3.photobucket.com/albums/y98...r/IMG_3631.jpg
http://i3.photobucket.com/albums/y98...IMG_3632-1.jpg
http://i3.photobucket.com/albums/y98...IMG_3636-1.jpg
http://i3.photobucket.com/albums/y98...IMG_3634-1.jpg
and front mounted with 24hrs of purchasing the car :)
http://i3.photobucket.com/albums/y98...IMG_3638-1.jpg
Continued in my quest to make sure the base motor is healthy , and gave it frehs oil and filter.
Also ordered a oil pressure, temp and boost gauge to keep an eye on things, aswell as a boost controller on its way.
http://i3.photobucket.com/albums/y98...r/IMG_3715.jpg
Also fitted a full system to get it breathing a little better, the system was off an s14 so i also had to swap elbows
http://i3.photobucket.com/albums/y98...r/IMG_3709.jpg
Also ordered a walbro 255 pump just incase the old one has become weak at all.
http://i3.photobucket.com/albums/y98...r/IMG_3716.jpg
now the basics are there ill concenrate on sorting suspension wheels and just using it :)
