hello to the whole rtoc forum just got rid of my chargecool kit wanted to have some inspiration ideas for my front mount intercooler so lets see the pics :)
http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
my new intercooler :cooter:
Where are you going to put it? I take it your going to cut the cross member?
Bit small dont you think ... :laugh:
I guess your gonna have to heavily modify your front bumper to fit that. I'm just in the process of fitting a modded 2wd cossie cooler and it fits behind the std bumper with little or no mods. You can pick them up for next to nothing. Think mines was £15! It gives a good improvement and allows room to move your air filter to the front of your car. Result in my books
Someones got one for sale in the classifieds at the moment
im going to be using this 1 on mine my kids got it for my birthday and i dont need to cut the bumper
https://www.rtoc.org/boards/picture.p...pictureid=3828
Mine fits in the grill area too.
You would have to ask gtmatt where he got it from though.
Heres the cooler on my tungy
https://www.rtoc.org/boards/picture.p...pictureid=3380
https://www.rtoc.org/boards/picture.p...pictureid=3378
Similar to the one on the front of your van brigsy.
:scratch: Learning moment here guys .....
But the OP's choosen FMIC , wouldnt something of that size produce lag ? ..
ahh, the joys of carb freeze...NAAAAT! :cooter:
yeah chris i still kept the standard grill on, just had2 trim them 2 sorta block clips on either side.. best just look at my album step by step pics :) the rad did have to go back a little.... best pic i have of the engine bay...
http://i44.photobucket.com/albums/f1...k_001/hjdd.jpg
firstly, raj.... that looks sweet!
secondly.. here is mine
http://i11.photobucket.com/albums/a1...02993Large.jpg
http://i11.photobucket.com/albums/a1...uk/cooler2.jpg
http://i11.photobucket.com/albums/a1...uk/cooler1.jpg
mines a bit big
and badley fitted lol
Dave
Dont suppose you want a spare front bumper for FREE ? its in white bump strips removed , as are the bottom slats. fog holes still intack Slight crack at the bottom of the bumper near the towing eye cover ,
Yours if you can make use of it . Pick up only though :agree:
anything free is goodmate.
but tbh a standard bumper just dont fit.
im sure another member would benefit more from yr offer mate
but thank u any way
ill post a pik in the week of how much is left of mine.
and its not alot
No problems Dave , Think Penfolds taken me up on the offer !
just a quick one...
looks like most of the big ones are bar and plate? are they 'glued' like the forge jobbies, or are they so big it doesn't matter. the leading edge of the tubes looks flat on pretty much all of the big ones, surely that wont let the air pass through smoothly, or am i just talking jibber jabber?!
Ah sod it i'm going to stick a pic of mine up again! :D;)
didn't they do a bigger one mark? :laugh:
http://i484.photobucket.com/albums/r...oject/int4.jpg
I'm currently fitting this one.
Mines in here
https://www.rtoc.org/boards/showthread.php?t=455
Which is fitted to another members car with standard front bumper now
My Intercooler is a little smaller to Blicks but involved no cutting of the 5 just a few drilled holes to hold it in place and I can still fit the OE grill again no cutting was required but I did have to change to a campus pulley and belt along with shortening the top alt arm support this was really due to the size of my boost hoses and my boost pipe run (routed like this to avoid the HT leads).
OE Grill Off
http://i252.photobucket.com/albums/h...0/SAM_0936.jpg
Grill in place
http://i252.photobucket.com/albums/h...0/SAM_1047.jpg
Top rad support bracket now a nice Pro Alloy jobby seem's to do the job nicely
http://i252.photobucket.com/albums/h...0/SAM_1041.jpg
Pipe run routing
http://i252.photobucket.com/albums/h...0/SAM_1036.jpg
very tidy
Subtle but seems to do the job :)
you guys must absolutely love cab freeze!
efi my freind EFIIIIIIIIIIIII:):):)
im gona sound dumb now but iv never been told so i ent gona know.....wats efi everyone is always talking about it.
Mat
Don't be afraid to ask questions and make mistakes, mathew, it's the only way to learn.:)
Heres my frontera grill mounted intercooler.
http://i3.photobucket.com/albums/y89...hebuild080.jpg
http://i3.photobucket.com/albums/y89...eetrice008.jpg
original pipe run
http://i3.photobucket.com/albums/y89...eetrice007.jpg
pipe run now
http://i3.photobucket.com/albums/y89...rtheyears5.jpg
I think you have the pics the wrong way round..
It looks very neat..sits nicley in place
how much psi can that i/c handle? and what is the flow like as it enters and exits?
I've always wonder how much affect it would have using lower performance parts.. albeit larger intercoolers - it just looks quite a sharp turn into the intercooler. I remeber reading an article and it stressing the importance of keeping things smooth..
Heres my new set up in the raider, probabley not the best for charge temps but keeps the front end o.e
http://i262.photobucket.com/albums/i...3022010263.jpg
Is that the pro alloy cooler?
I don't know anyone whos run one before so couldn't say is it was a good or poo!
Ok not as big as some of the lads coolers on this thread, but still quite big and keeps stock looks. So thats a Win Win in my mind. :D
The Ford boys seem to love these coolers on there mk 3/4 Escort's and mk3 Feista RS.
so wats the advantages having efi apart from not getting carb freeze and is it expensive to have fitted.
cooling is a function of the size of the IC and the air flow across it
The only Hi Flow Low volume Intercooler out there
httphttps://www.rtoc.org/files/Technical%...et%20scoop.JPG
https://www.rtoc.org/files/Technical%...osedbonnet.JPG
Looks really functional that set up, just a shame about the hole in the bonnet it make it work so well. :cry: You must get some good act from it. :)
Russell good solution, nice and neat ;)
Good clean air flow been a bit higher as well, I vented the front of my bonnet in that area on the vag 5 and even this without the cowling / ducting made a difference. The stamped bonnets look good in the usual areas they get done but not very functional when driving due to high / low air pressure and can go against the way the 5 engine bay cools - nice to have in traffic but not much else
DG
what are peoples opinions when you cut the front cross member out to fit a intercooler..
Sorry to revive a whole topic, but surely better than starting fresh.
just cut it, weaken or not if you have a frontal in a r5 your pretty much dead anyway
a smaller fmic is maybe not as effective as a larger cooler but no cutting is nesersary
https://www.rtoc.org/boards/picture.p...401352&thumb=1 https://www.rtoc.org/boards/picture.p...401352&thumb=1
my front mount
http://img.photobucket.com/albums/v6...d/DSC00972.jpg
fits nicely behind std bumper also
