Re: How not to build a flow bench...
Rob@Backyardracing
so are there any part numbers on the heads to identify which head is which? i couldnt seem to find any...
but then again, i suppose in terms of a stock motor, stock CR etc, either of the heads will make the same hp anyway (within ~5hp) would they? or is it a case of some have better heads, but milder maps or cams, hence still make 166hp or whatever it is
There are plenty of numbers, but not sure what they all mean. The best I can offer is that PH1 has the large oval exhaust port, and later heads seem to have a date etched on the inlet face below and between the 1st and 2nd ports (from the cambelt end).
andyrg
i have a F4RT Head with a cracked port if that will help with any of this development ;)
Andy
I guess that depends upon how interested anyone is, at the moment I have enough to get on with for a while yet. Don't chuck it away just yet..
Andrew Cooke
Jesus no, it took me long enough to get rid of it last time :laugh:
:laugh: :disagree:
I've started making the bits up to let me test the F4R head. First job bore out a bit of the blue block to 82.7mm
http://i567.photobucket.com/albums/s...g?t=1285422749
It's all about the precision :laugh:
This is my best guess for where the bead bolts should be relative to the bore
Oh, and I dismantled a head
a full set of S shaped valves, cheers Ant :D
a few more bits whilst I'm having a coffee...
I finished the blue block, drilled and tapped some holes so I could fit some M10 studs and made some dowels to hold the head in the right place relative to the bore.
http://i567.photobucket.com/albums/s...g?t=1285440301
The head is held down with 4 nuts
I've started on something to open the valves
all being well I'll get that finished and do some tests later tonight. :)
all done:
and just for fun, a comparison between GTT, Gordini, and 172 heads :cool:
http://i567.photobucket.com/albums/s...g?t=1285447184
you got a b18ft head you could test to see how it stacks up against the c1j head just out of curiosity:D
SCHWARTZ
Sorry, I'm clean out of heads now :)
I'd guess that it's close to the Gordini head, although the bigger bore may help a bit.
It Would be nice to see a B18ft cam against other heads :)
