If you can make one up scoff.Let me know how much you want and ill send you some funds.
Matt, that would be pretty cool if you don't mind trusting me with it. I could have it back in the post the next working day. Pics are pretty good, I'd need to know what that zener diode was and what the transistors are, having it first hand to copy would be great, no chance of error then.
newb, if matt sends me his down I'll make you one for free. did you open your ECU to see if the hardware was there ? (R-tuner eprom in a socket should be visible enough I guess). I'd like to have an interface incase I ever need to map an R-tuner. making a couple up is no problem at all.
No probs Scoff.
The R-Tuner chip should be in a socket type thing...I can't rembember the name of it....but the chip itself is removable...on the underside of mine is what looks like a blob of araldite....with tiny connections going to it.........I'll post a photo of it tonight.......
thats the eprom (or rom), it'll be stamped 27Cxxx or something like that, I don't know what eprom that ECU uses.
matt, if I PM you my address do you mind doing that ? I can take a diagram from it and get it back to you, then I can build some up from the diagram.
I looked around for people seeling r-tuner, no one to be found, I've asked henke if he's interested in supplying me just the rom's, it might be that he cannot be bothered with the hardware anymore, or the support of it. but, he may not mind selling someone a stack of roms.
Thats more of a response than I got out of Henke.......
PM me you address Scoff I'll send it to you........
Matt.
lol, thats the point, I havn't had a responce yet :confused: most likely he will say no but you don't get unless you ask. I'll send a pm now :)
Is this any use....?
The numbers on top of the chip are......
R-Tuner v35
6364
785230
I think those numbers are specific to fastchip/henke, I think that will be v3.5 probably, other numbers could just be a batch number and a serial, which I believe you need to active the rom on first use, when you first connect the r-tuner software.
http://s367.photobucket.com/albums/o...t=SDC10032.jpg
my ecu is different?
on the sticker it says.
r5-gtt-i powered by fastchips.
3c20
7a1421
ooh, that could be a non-programmable chip then, ie, a map that is fixed into the rom. fastchip sold a lot of those for 16v turbo conversions, I don't know if they offered the same for the R5. are you sure it is an r-tuner / re-programmable ECU that you have ? perhaps BB used R-tuner to map the engine and then sent the map's back to henke so that he could re-produce it into a fixed rom, on sale to the masses.
No he said it can be remapped.then offered me the kit to do this.£350.00 quid.
looks like another customer for the adaptronic shop
ah but, that kit will include a new ROM that allows the ECU to be re-mapped. If you already had the r-tuner (re-mappable) rom then the kit should have been more like 50.00 at worst, for an interface, like the one matt has pictured.
I fear you may not be able to re-map that. the rom should most likely say "r-tuner" on top of it like matt's.
Anyone want to buy an R-Tuner kit????:laugh:
Ill give bb a ring to confirm what they will sell in the kit for the price tag.
But do i have a williams ecu then. part no on my ecu is7700860285
let us know what BB say. I'm finding this r-tuner business quite interesting again.
I used to use tewblog a lot with my old wideband/logger. I went off it once the new versions wanted me to pay to use all the features.
i must have a williams ecu siemens is the one i have.
Yeah also thought that.Probably right as they would be more available.
well the news from bb.19 16v ecu and a non remappable chip.:crap:
Cheers for the support, and info matt and scoff. Not a bad thread though.:p
Ah, well at least you know...what was all the B/S from BB about the re-map software costing £350 then......:confused:
well young junior is full of b/s down there.I spoke to him at santa pod,when he had a c1j on displayIt had that tubular manifold they was gonna sell it was made out of cast. I spoke to him later and he said he was making them out of ssteel,however and stated he new nothing about talking to me about a cast item.This was even though he was ranting that he was making them out of cast for heat transfer and strength for half an hour.:jerkoff:
like I say guys that £350 will be a complete r-tuner kit, fitted I hope for that, not just the software - which itself I think is free, I downloaded it years ago when it was on henke's site.
