Thanks mate :agree:
Thanks mate :agree:
Good update :)
Brass bleed screws FTW. Not the price of them tho!
Cheers :agree: wanted to do some more today but it's pissing down :mad:
Yeah the brass bleed screws are much better mate but as you said not cheap for what they are
It pays to lube/spray the dizzy cap points and rotor arm with some WD40 :)
Looks really smart :agree:
Ok mate thanks for the tip will do that :agree:
got some door cards the other week some phase 1 rears as mine are sagging phase 2 type and some phase 1 fronts refurbished by the previous owner just waiting on some new speakers then i will fit them when i have the time
http://i1347.photobucket.com/albums/...ps4f90c195.jpg
http://i1347.photobucket.com/albums/...ps8b22fceb.jpg
http://i1347.photobucket.com/albums/...psade3b17d.jpg
http://i1347.photobucket.com/albums/...ps85827bda.jpg
http://i1347.photobucket.com/albums/...pse461b7cd.jpg
hopefully the weather is better tomo then i can get the water pump done
got a bit done today done a system flush as i put in speed flush the other day but by time the engine fully cooled so i could flush it was dark. I then fitted the water pump, waiting on some new hoses to come then i can finish off
http://i1347.photobucket.com/albums/...ps7b5d62ac.jpg
http://i1347.photobucket.com/albums/...ps19837c9a.jpg
http://i1347.photobucket.com/albums/...psd37ef1ec.jpg
http://i1347.photobucket.com/albums/...psf277b64a.jpg
http://i1347.photobucket.com/albums/...psafe47713.jpg
old water pump off
http://i1347.photobucket.com/albums/...ps71008338.jpg
http://i1347.photobucket.com/albums/...psaf483783.jpg
new water pump and gaskets
http://i1347.photobucket.com/albums/...ps8eb3b19f.jpg
as it was easy access thought i would change the oil filter
http://i1347.photobucket.com/albums/...pse25b2df8.jpg
http://i1347.photobucket.com/albums/...ps350b38ed.jpg
new temp sensor and thermostat
http://i1347.photobucket.com/albums/...ps6438b90e.jpg
http://i1347.photobucket.com/albums/...pscae80ac5.jpg
new water pump bolts
http://i1347.photobucket.com/albums/...ps5ece765c.jpg
water pump all bolted on with new belt
http://i1347.photobucket.com/albums/...pse8b17105.jpg
new blue ht leads on just need to tidy them up with some cable ties
http://i1347.photobucket.com/albums/...ps2e9aaf52.jpg
dre:niceone:
You're lucky to have got those bolts out without any snapping :eek:
Keep the pics coming :niceone:
All of them came off with ease lol this little motor ain't been bad to work on, my Williams was harder work, nice having the room :).
cheers Nad
coolant system all sorted now and working a treat :cool: got my hoses to and changed them to, still got to do a little tidy up with a few things
re rooted my boost pipe instead of going over the top
http://i1347.photobucket.com/albums/...psf25d46b6.jpg
new coolant and breather hoses
http://i1347.photobucket.com/albums/...ps7c449ecd.jpg
tried to fit my old air box but it just don't fit with the bread bin intercooler so just going to keep the cone filter
http://i1347.photobucket.com/albums/...ps57b3727c.jpg
http://i1347.photobucket.com/albums/...ps34c551e4.jpg
http://i1347.photobucket.com/albums/...ps35bbc40f.jpg
http://i1347.photobucket.com/albums/...ps323506a1.jpg
cleaned
http://i1347.photobucket.com/albums/...ps59c156a3.jpg
new relay
http://i1347.photobucket.com/albums/...ps34041d2b.jpg
pipes all fitted
http://i1347.photobucket.com/albums/...ps122cad53.jpg
http://i1347.photobucket.com/albums/...ps30683e82.jpg
http://i1347.photobucket.com/albums/...ps04348faf.jpg
changed my wipers as the straight ones at the end were useless just need to get some bolt caps for them
http://i1347.photobucket.com/albums/...psdc1c0174.jpg
http://i1347.photobucket.com/albums/...psa4e79150.jpg
http://i1347.photobucket.com/albums/...ps0e6ba77d.jpg
got some Avo springs 30mm drop as i dont like the drop and feel of the springs on there at the moment my spax shocks are good but the springs are to harsh and low, might as well change the top mounts and bearings to so got them to hopefully do them tomo
http://i1347.photobucket.com/albums/...psa75380c0.jpg
dre
The bolt caps are part of the wiper arm.
Coming along nicely mate.
:agree: nice one for the stickers GTTurbo mate will get it fitted soon :)
Good stuff mate. If you are struggling for wiper caps I am sure I have a couple knocking around for you, just cover postage and there yours.
That would be great mate let me know how much you want
Nice work fella, keeping busy ;) out of interest where and how much were Avo coil springs? cheers :agree: :)
Dre, sorry mate bit confused is it the caps that cover the 10mm nuts or the caps for the end of the blade that holds the blade on?
I will have a look Dre :)
They are riveted on from memory, got some in the unit will have a look
They are, see attached picture
Nice 1, as they do go back on but easily pop off.
Yeah easy pop off style :agree:
Now just got to source some front shocks as mine are fooked :(
got some HT lead clips
http://i1347.photobucket.com/albums/...psb92e25a2.jpg
http://i1347.photobucket.com/albums/...pse3c3d626.jpg
wanted to change my springs today but it looks like one of my shocks has had it plus i couldn't believe the amount of floating with the springs that were in there :eek: i did hear clocking noise now a ten now know why
i have read that lowering springs with the phase 1 set up can be a bitch the new Avo springs look near on identical as the spax so i need to get some new front shocks and sell these new springs :rolleyes: or get coilovers and sell both sets
never even needed spring compressors to take off :sad2:
http://i1347.photobucket.com/albums/...ps020a5ec2.jpg
http://i1347.photobucket.com/albums/...ps3053d3d7.jpg
http://i1347.photobucket.com/albums/...psd3b2d2ce.jpg
http://i1347.photobucket.com/albums/...ps0c89a289.jpg
other side :eek:
http://i1347.photobucket.com/albums/...ps49ffc903.jpg
http://i1347.photobucket.com/albums/...pse9ff0be4.jpg
avo on the left spax to the right
http://i1347.photobucket.com/albums/...ps68210e7b.jpg
changed the top mounts and bushes
http://i1347.photobucket.com/albums/...ps6e640e5c.jpg
new
http://i1347.photobucket.com/albums/...pse5a336e8.jpg
2 sets of springs and no shocks lol
http://i1347.photobucket.com/albums/...ps3a33a96a.jpg
stripped the arb bushes got new ones on order
http://i1347.photobucket.com/albums/...ps100acdea.jpg
http://i1347.photobucket.com/albums/...ps2201a7c7.jpg
http://i1347.photobucket.com/albums/...psb0c07cd9.jpg
will update when i have got my shocks or coilovers then no more spending as i have spent a small fortune lately :rolleyes:
for my later project got a t25 hybrid be a while till i fit this with some cams and things :agree:
http://i1347.photobucket.com/albums/...ps8b4d0eab.jpg
http://i1347.photobucket.com/albums/...psefe04107.jpg
http://i1347.photobucket.com/albums/...pse5434290.jpg
dre
got a few more bits for the 5 managed to find some shocks for £40 going to fit my springs, with new top mount ring and bearing and give them a paint over
http://i1347.photobucket.com/albums/...pse1bbba01.jpg
http://i1347.photobucket.com/albums/...psd539ea2e.jpg
going to fit these on them
i put my sticker on so painted it all black first
http://i1347.photobucket.com/albums/...ps3d77e32f.jpg
http://i1347.photobucket.com/albums/...ps96a82159.jpg
http://i1347.photobucket.com/albums/...psbd145589.jpg
got some powerflex arb bushes will fit them once i fit the shocks
http://i1347.photobucket.com/albums/...pseabed7ef.jpg
got myself an oil cooler with thermostat
http://i1347.photobucket.com/albums/...ps767dacfd.jpg
http://i1347.photobucket.com/albums/...psd70cc1ef.jpg
http://i1347.photobucket.com/albums/...ps8561c8fa.jpg
also got my low temp radiator fan switch and rear window sticker :cool:
http://i1347.photobucket.com/albums/...ps86c4fba6.jpg
dre :agree:
Coming on nicely that mate :agree:
Good work buddy. I like a project with loads of pics.:agree:
Cheers peeps do like taking a photo or 2 lol :agree:
Sticker looks good ;)
Good work enjoying the updates
Def coming along nicely mate. :)
Love the pics etc. Makes me want to get my butt in gear and do some more work on mine!
Rear badge looks a lot better now :agree:
stripped the spax shocks i bought as im going clean them up and put my springs and new top mount rings and bearings.
http://i1347.photobucket.com/albums/...psb6b9fcd3.jpg
http://i1347.photobucket.com/albums/...ps3c000e18.jpg
old springs
http://i1347.photobucket.com/albums/...ps8d9aa068.jpg
new springs
http://i1347.photobucket.com/albums/...psb79fc3a7.jpg
you can see the difference in the phase 1 and phase 2 top mounts. The bottom half is the exact same on both phase's its the top that's different.
http://i1347.photobucket.com/albums/...psd62f4eb2.jpg
http://i1347.photobucket.com/albums/...psdfbfc20d.jpg
so i just used the bottom half off the phase 1 and im going to clean up the top half off the phase 2. Not got much else done, in no rush as the car is off the road anyway.
http://i1347.photobucket.com/albums/...psae4c208e.jpg
also got a few more bits for the 5 a few were Christmas presents form the misses :)
got a breather pipe restrictor as im missing the large one and a new relay
http://i1347.photobucket.com/albums/...ps24911f22.jpg
got a breather pot need to polish it up
http://i1347.photobucket.com/albums/...ps9f4b9c4e.jpg
http://i1347.photobucket.com/albums/...psba559c11.jpg
piper cam 270
http://i1347.photobucket.com/albums/...ps2ccc56be.jpg
got a new air filter for Christmas as i wanted one enclosed and since fitting my bread bin intercooler and moving my header tank there is no chance in fitting my original air box :sad2: and as i have vents in my bonnet there is always a chance of water getting to the cone filter i have now:disagree: so this one will do me nicely was imported from italy
http://i1347.photobucket.com/albums/...pse0a672a6.jpg
http://i1347.photobucket.com/albums/...psdf9b0be7.jpg
http://i1347.photobucket.com/albums/...psd9b96aef.jpg
http://i1347.photobucket.com/albums/...psee052c40.jpg
also got a t shirt off the misses and some key rings to
http://i1347.photobucket.com/albums/...ps4167a320.jpg
http://i1347.photobucket.com/albums/...psb3c31e66.jpg
bought myself a oil catch can to
http://i1347.photobucket.com/albums/...ps1b806238.jpg
http://i1347.photobucket.com/albums/...psef571d72.jpg
so i am going to busy for awhile :)
Love that airfilter. Where did you get oil catch tank from please mate
hi Chris the oil can was from ebay was only £22 delivered here is the item no 230592901035
Thanks mate car looks amazeing
cheers fella cant wait till the weather gets better and i can work on it and drive it
I know what you mean all its done is rain here today I don't mind working in the cold its the rain that does my head in
im the same mate i have a garage but its got clio williams in there with all my tools and parts im thinking in building a bigger garage or at least a car port i can work under as its always fooking raining :mad:
