ashy, nice one :)
ashy, nice one :)
Did you want the phase 2 1 aswell matey to play with??
ashy, stick that spare coolant sensor you have in too and I'll make you that converter we talked about.
james, that might be handy, I will do some more reading yet though because it's the phase 1 that I'm not sure about. If I get to a stage where I've bought a programmer then I'll give you a shout. :)
Well engine part in just won't mate up with gtt box will try again tomoz as bloody cold.
(Excuse the state of the rocker cover and the fuel rail cover which will not be staying will clean up rocker once I finally get it running).
Its looking good james. cant wate to see it turbo'd:)
Excellent project look forward to seeing it in action.
Can't wait to see this finished, gunna be fantastic, I know Scoff has done it already but his is an out an out drag car where as this will be used on the road, now that will be great
Going to go out now and have another go. It's so cold:( ohwell need it running as it's depressing seeing it sitting their.
Got the bar steward on:) But my engine crane will now not lift the engine high enough to get it back in the car:crap:. Ohwell enough for tonight will sort out crane in a couple of days I am fapping freezing now.
can you not just shorten your sling?
I have got the sling so short as it will go but for some reason it will not go as high as it used to when you pump the handle it does nothing it's as though know pressure to force the arm up anymore. Prob need some kind of bleed of lubricate replacement I have found the drain hole just no idea where you fill it up??? Clarke CFC1000 anyone got any idea??
either low on fluid or the ram is knackered m8 had this with my one ended up getting the ram repaired by a local firm
You need to keep the ram vertical and remove the rubber bung. Fill until fluid starts to come out of hole. Replace the bung and with the release valve kept open, pump the ram handle several times. keep pumping and release/close the valve slowly. See if it goes all the way up. When its up force the ram down while opening the release valve. That should bleed and prime the pump.:agree:
Got the fecker in @ last just come in as it is now raining, still got the driveshafts to put back in.
Kind of sorted the engine crane still dogey but managed away around it:)
Could you do me a huge favour and while you have the grill off measure the area infront of the rad as i am looking to put a grill mount in. If not thats fine i was planning on doing it at the weekend anyway! Looking really good by the way!
I need to change to the cable type throttle bodie, are there other throttle bodies that fit then? I've seem a couple on ebay one for an 850 and one for a v40 will either of these fit/do?
Cheers
Andy
850
http://i17.ebayimg.com/05/i/001/16/43/6b40_1.JPG
and the v40
http://i12.ebayimg.com/04/i/001/16/43/6efc_1.JPG
What size are valves on the 172 head?
Did you sort out the sprung bolts on the down pipe? I found one of them in my garage the other day, i could post it to you if you need it? I know it can be tricky without the little cups!! I could get you a second one made up aswell if you want a pair? Lettuce know marrow :)
I have got some very chunky bolts with some big washers just awaiting for a fellow RTOC member to post me some gtt ex springs as I have misplaced mine:( then all should be good exhaust is on at the mo without the ex springs.
Going to try and start some wiring tomorrow if I get some time
Ill get another cup made and send them down to you, got some old springs somewhere too, i'll see what I can dig out. PM me your address again marrow.
Couple of update pics,
172 rad and fan in place (tight fit) looks like a slim line fan will be on the cards.
Many thanks to Ashy and Scoff for all the advice. Won't be long now as I have started the wiring so she should be started very soon.
Looking good matey, bet you cant wait to get it up and running... i loved mine when it was just NA. Went like stink and you could give it full beans without worrying about it blowing up!! Great on the track.
It is tight that rad, Mat C has one of those to go in with his 225, I bet he'll be interested in those pics!!
looking good james..when are you hoping to turn it over?
I wish I could fit a rad as big as that. its getting there :)
That is a chunky fan and shroud isn't it, the size of the rad doesn't look far off the size of my 19 16v one i have. I needed a slime line fan even with the volvo lump.
Scoff, you might be able to fit one in there if the intercooler was pulled slightly forward, thats one of the reason's why mines mount abit further out from the front panel.
Its looking good mate;)
Good work James. Im loving all these projects on here :) some really good work going on in the club..:agree: keep it up chaps as its good to read....
is that a standard bonnet shut on there now mate?
I can't fit mine. Just not enough room. Alternator in the way. It may go in with some thought. Anyway, that rad does not look like a comfortable fit. If its fouling on anything i would make sure its securely fastened down. The plastic side housings on them rads are quite thin.
Been out and had a look at the bonnet today and to be honest looked at the standard bonnet it catches on 1 side of the inlet plenium with a bit of an angle grind I reckon I could get it to close with the plenium in place but then how much movement will there be from the engine with the standard bonnet angle grinded might be safer to use the 16v bonnet
I was looking at mine today james, I have a solid rear engine mount which sits about 1" lower than the standard mount, it drops the whole plenum by about 0.5". I rekon with a the standard bonnet it would still catch the plenum (just) even with the throttle area machined down (which I guess is the bit you are talking about). with my engine on standard mounts a standard bonnet was a definate no-go. On my new engine mount (different gearbox) I've got it a little lower still, a standard bonnet might go.
point is, if you can be bothered making a new rear engine mount or modifying the black "V" shaped mount that bolts to the gearbox you might get away with it ? :)
bah, don't be lazy ;) I dropped mine down to try and keep the driveshafts parrallel with the floor, I had them perfectly level with the old gearbox. they sit a bit higher than I'd like now even after dropping the engine a little more. sump is actually lower than the subframe now, I'll have to be carefull on speed humps :D
totally standard james, gsf ones.
R5 16v Bonnet now on so enough clearance for inlet plenium
