Anyone know if there are any other renault models that use the same rear shocks as the ph2 11 turbo?
i am pretty sure 1.7 gtx models will have the same shocks as they use the same axle.
i got a pair here ,i can check part numbers if you can tell me yours .
you can use shocks from renault 19/megane as well but you will have to swap
the bottom mounting bushes as they are a different internal diameter .
I bought a pair of new shocks and it has made no difference at all.
Tha car is still sitting lower than it used to be :(
I give up with these sheds i really do :mad:
sitting lower would not have much to do with the shocks.
you may have a problem with the axle etc
