Scoff
stuart is an interesting case. he has reached the limit of what his particular engine will do because adding nitrous made no extra power at all. imagine that, it's like he's literally maxed it out post chamber. if he had larger exhaust valves, a better manifold and a bigger turbine then maybe it would be a different story.
agreed, you would not want to loose stroke on the c1j. it is just about right for the best cylinder heads we have seen so far. like andy says, improve the cylinder head (read cross-flow, maxi and so on) then you would want to go longer still else you will need a lot of rpm to reach the limit of the new cylinder head.
