is it worth getting these balanced/lightened or is it not
a done thing?
also as well as crankshaft an flywheel what other items can
be lightened an balanced?....pully wheel??
cheers
a done thing?
cheers
depends what you are gonna rev the car too.
balancing stops the engine lunching itself due to vibration.
lightening will help it rev better and you gain 'free horsepower' as the engine has less weight to turn.
the balancing helps the reliability.
I doubt you can get enough weight out of a rod to gain much in the way of performance. What it will do it allow the engine to rev higher, but since noone revs a GTT high enough to worry the rods it's all a bit of a waste of time. You're more likely to weaken something and have it fail for that reason.
