Cammed F7R Hybrid Engine
I have for sale a rebuilt F7R hybrid lump
The rebuild was carried out approximately 7k miles ago
New shells, h/gasket, skimmed, valves reground, water pump, cambelt kit all replaced
I didn't carry out the rebuild but do have some receipts for the parts etc
Reason its 'hybrid' is it has a worked Clio 16v head on the Williams bottom end.
spec as follows:
- F7R block
- F7P head,
- Kent 1601 cams
- Kent pulleys
- Ported and polished head
- F7R Williams ecu,
red rocker cover and cambelt cover not included, will come with just a standard silver cam cover.
no starter or gearbox, can be included at cost.
everything else included, so inlet manifold, flywheel, throttle body, sensors, wiring loom, injectors, the lot.
engine is still in the car and essentially running so can be viewed/heard if needed. I also will post a video of it running when the darn thing loads!
£550 ono collected from Ambergate in Derbyshire
cheers
Ben
http://i14.photobucket.com/albums/a3...ps02zbkp0d.jpg
http://i14.photobucket.com/albums/a3...psxpv66d2e.jpg
http://i14.photobucket.com/albums/a3...psmcd9zdrp.jpg
