Re: Steering Wheel Refurb
That looks bang on. Top job :cool:
Superb job :)
What did you put on the leather mate?
Top work mate! Might send u mine ;)
I've got a spare OE wheel here but the rubber bit at the top has detached from the frame where someone has been gripping it too tight or its just worn loose over the years. Is there a way to sort this?
Was thinking about injecting glue through the rubber and then seeing what happens... Other suggestions welcome, it seems too good to bin.
I forgot to say, the leather refurb looks really good.
mingblus3
Tap into google "steering wheel refurbishment", there a few company's that can 100% restore even the worse steering wheel if you don't fancy trying it your self. :agree:
Possibly even be able to refurb the o.e. gear knob to. ;)
Gtturbo
Superb job :)
I used a leather re-dye treatment. It involves removing the original coloured layer, repairing any cracks etc and re-colouring the leather.
TopCat
Thanks mate :) send it down ;)
mingblus3
Thanks dude. I haven't seen one go like that so couldn't really say. Depending on where the split is, you cohld use an adhesive to stick it back together and then smooth down the area.
You just need to be careful that the adhesive doesn't melt or burn the foamy rubber.
